Mamba Max Problem?
Mamba Max Problem?
I have the mamba max and when I program it the steering only works. No throttle. Fresh batteries in my remote. I've also tried different remotes and reprograming the esc multiple times. The motor beeps and does everything the manual says but no throttle. Is the motor bad?
Tech Legend
Trader Rating: 51 (100%+)
Turn your mamba off and make sure you have the throttle servo setting correct. Then reprogram the mamba.
