Brushless Motor Bearing Removal
I've heard racers discuss replacing the standard bearings in brushless motors with high performance bearings. What tricks do y'all have to remove the bearings? I have a mod motor that needs a bearing or bearings replaced, but I'm hesitant to just start banging on the bearings to get them out. Do you need a torch? Or will a heat gun do? Are there different procedures for different motors?
On my Hacker 17.5 the bearings just fell out with a little tap. The tolerance on the parts is very loose. I am not sure about others. If the bearing is already bad, just put a screwdriver on the inner race and just bang it out. On good bearings you should never touch the inner race.
http://www3.towerhobbies.com/cgi-bin...?&I=LXVFW2&P=7
That was easy.
Anyone else have any experience with this little guy?
That was easy.
If you are working on a Novak motor they don't recommend replacing the bearings because they are glued in the aluminum endbell. I found the way around that was to put pressure on the bearing with the bearing removal tool (like the one noted above) and then with the bearing tool held in a vise, heat the endbell with a heat gun. The aluminum expands more than the steel bearing and when the glue bond breaks you can hear a "pop" and the bearing comes out easily the rest of the way.
Here is a tool by Hyperdrive to remove and install the bearing. I tried it it; works great. No heating neccesary.
http://www.lefthander-rc.com/catalog...oducts_id=1378
When reinstalling the bearing I use a high temp red Loctite to glue the bearing back in. Motors sometimes get too hot for the standard grade of red loctite.
john
john
Super Moderator
