Fast Engine
Old 11-05-2008, 08:18 PM
Default Fast Engine
Whats a super fast engine for bashing for a 1/10th scale car
ccordero85 is offline
Old 11-05-2008, 08:57 PM
Riketsu's Avatar
Trader Rating: 34 (100%+)
jlr red dot
Riketsu is offline
Old 11-05-2008, 09:18 PM
Wynnum_Racer's Avatar
Murnan Modified Novarossi .12 SCT
VERY VERY QUICK
Wynnum_Racer is offline
Old 11-05-2008, 10:49 PM
Riketsu's Avatar
He said bashing... Murnan Modified engine are not for bashing....
Riketsu is offline
Old 11-05-2008, 11:50 PM
NiTrO BoOsTeR's Avatar
VERY VERY QUICK
when ur as rich as this guy a Murnan is for bashing aint that right jason.
NiTrO BoOsTeR is offline
Old 11-06-2008, 01:54 AM
Roelof's Avatar
OSMAX 18TZ with a faster gearing.
Roelof is offline
Old 11-06-2008, 05:36 AM
jman37's Avatar
If your bashing... why not throw an .18 in there !!!
jman37 is offline
Old 11-06-2008, 06:16 AM
spenzalii's Avatar
Agreed. If you're gonna bash, that OS18 is probably your best bet
spenzalii is offline
Old 11-06-2008, 06:17 AM
Big Jeff BBQ's Avatar
Max Power XXLS3 Massimo Fantini !
---------------- - OR -------------
Murnan Modified Plus 12 Ceramic Bearings all the way!:
A Few Head Shims and a couple of gallons of 40% should do the TRICK!
later
Jeff
Big Jeff BBQ is offline
Old 11-06-2008, 06:43 AM
Go with the OS.18TZ but put some wide tires on the rear for traction.
nitrohead5300 is offline
Old 11-06-2008, 10:50 AM
Yea it was either the os.18 or the .12
Old 11-06-2008, 12:35 PM
Serpent720's Avatar
Trader Rating: 11 (100%+)
I have a RB Mod Novarossi Plus .12 3SCT. Off the track, can't keep it straight.
Serpent720 is offline
Old 11-06-2008, 01:13 PM
Artificial-I's Avatar
Trader Rating: 17 (100%+)
The os 18tz will decimate all , first we have to order some parts from japan. Only draw back is run times and the fact that its just a ton of torque and makes it hard to drive , the jlr otherwise is sick fast and more controlable.
Artificial-I is offline
Old 11-06-2008, 01:37 PM
lil-bump's Avatar
Trader Rating: 89 (100%+)
I would go with the JlR Red Dot or the OS 12tz or 18tz. Any RB or Novarossi in my mind is to expensive to bash up and down the parking lot.
lil-bump is offline
Old 11-06-2008, 08:12 PM
Picco JLR .12 is the way to go. AB modded version is of the charts, most other .12's don't stand a chance and here is the dyno to prove it. Stock $179, great basher or racer.
OutlawIGT2 is offline
