cleaning
Best way to clean without a compressor? Save until you can get a compressor! It is painfull otherwise. IMO
the long weekend at the track way at the hotel remove radio tray motor and tank fill bath tub with water dunk car pull up scrub with tooth brush dry with hair dry then wd40 it
the at home way remove everthing like above place in dishwasher yes i said dishwasher and wash do not let it dry it do with the hair dryer then wd40
if you dont have a dishwaswer use the water hose and simple green
or if you scared of the water take all apart to bare chassic clean each peice by hand imo it to much danm work
Dishwasher?! Good idea....i gotta try that.
......................................__.......... ......................................
.............................,-~*`¯lllllll`*~,................................... .......
.......................,-~*`lllllllllllllllllllllllllll¯`*-,....................................
..................,-~*llllllllllllllllllllllllllllllllllllllllllll*-,..................................
...............,-*lllllllllllllllllllllllllllllllllllllllllllllllll lllll..................................
.............;*`lllllllllllllllllllllllllll,-~*~-,llllllllllllllllllll............................. ...
..............lllllllllllllllllllllllllll/.........;;;;llllllllllll,-`~-,...........................
...............lllllllllllllllllllll,-*...........`~-~-,...(.(¯`*,`,..........................
................llllllllllll,-~*.....................)_-..*`*;..)..........................
......................f`-,.........`-,/...*-,___,,-~*....,-*......|...`-,..................
Engine and electronics out, Paint brush hard bristle type dust off as much as you can.
Shower hot very hot water, shampooo and brush again, take it out hose it down with WD40 let sit in the sun all day.
Air compressor with simple green, works great.
yeah i said dishwasher
