Competition GFX mods
I'm cutting mine with a milling machine. THe window will be 1/4-3/8 larger than the opening and milled down the thickness of the case so it will be flush. I then plan on gluing it with either silicone caulk or shoe goo. Maybe JB weld will be stronger? I sometimes put my other quasar pro charger on top of the gfx on my pit tabel, it needs to take some abuse.
Maybe you could look around for a window mod kit for a pc. It has the moulding and everything you need to install it. I have found several but not the shape and size I need.
#20
I haven't done it yet, but John may be able to help you. If I were to guess maybe charge ifno like it shows on the graph while charging/discharging.
what do you think John?
#22
Originally posted by Tres
Randman: I mainly looked at realtime sec & pack voltage
Tre's
www.tresleonard.com
Tre's
www.tresleonard.com
-Dave
#25
This is the one the Tres did for me
I had a red light in the back but it burned out
#26
R/C Tech Elite Member
Tre's
www.tresleonard.com
Tre's
www.tresleonard.com
Do you need any software to view the charging parameters on the cpu?
#27
I think you need Hyperterminal.
Just go get a Compaq or HP Pocket PC
#28
Company Representative
mike_Webb: is correct...
You can use hyperterm, which comes with windows..
Tre's
www.tresleonard.com
Tre's
www.tresleonard.com
