Like Tree7Likes
VTA tuning Q&A
Old 01-12-2009, 11:41 AM
  #151
reenmachine's Avatar
Trader Rating: 26 (100%+)
Originally Posted by danketchpel
Can you guys post a link to the ~$10 scales you're using?
There are a bunch on amazon, but I think I like this one the best:
http://www.amazon.com/ZX-600-Digital...ref=pd_sbs_k_3
You need to get a calibration weight to make sure they're all accurate as well:
http://www.amazon.com/Gram-Chrome-Ca...ref=pd_sim_e_4
reenmachine is offline
Old 01-12-2009, 11:48 AM
  #152
TwoTone's Avatar
Trader Rating: 12 (100%+)
I will be needing to do this in the near future. I have a pretty decent digital scale now and may just "work it" to get front/back & side/side numbers.
BTW, I spoke with Novak tech support today re the Havoc ESC vs the GTB. He said that the only real limitation of the Havoc controller comes with the lower turn motors, the min turn motor for the Havoc is 8.5 so I don't see any "real" problems for this class. I also decided to order the optional cooling fan for it. Maybe it's overkill but cooler operating temps for any electronics is a good thing.
Hopefully they start shipping soon.
I'm thinking about trying these:
http://cgi.ebay.com/ws/eBayISAPI.dll...:X:RTQ:US:1123
He makes his money on the shipping so 4 scales for $30 doesn't seem bad, throw in a 500g weight for cal.
TwoTone is offline
Old 01-12-2009, 01:02 PM
  #153
That looks like a pretty decent unit. I can't believe they can sell that for ~$9, seems impossibly cheap. China..........
danketchpel is offline
Old 01-13-2009, 03:05 PM
  #154
Kregger's Avatar
Just out of curiosity does any using the 21.5 actually hit the FDR of 4.2 when they race?
Kregger is offline
Old 01-13-2009, 03:25 PM
  #155
Trader Rating: 21 (100%+)
Default 4.2
Kregger ... I was at 4.21 before changing this afternoon.
lidebt2 is offline
Old 01-13-2009, 03:28 PM
  #156
TwoTone's Avatar
Just about everyone at my track seems to be at around 4.2
TwoTone is offline
Old 01-13-2009, 05:07 PM
  #157
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Our track is short and technical. 4.2 is just too much for it and the car seems to have a good balance of speed and torque at around 4.5 or 4.6.
liljohn1064 is offline
Old 01-13-2009, 05:09 PM
  #158
Kregger's Avatar
Thanksfor the replys guys. Somone else and I normaly gear around 4.3-4.4.
Liljohn. How small is your track anyway?
Kregger is offline
Old 01-13-2009, 05:34 PM
  #159
myrxseven's Avatar
Trader Rating: 13 (100%+)
Is anyone running a losi xxx-s at all? If so, is there anyhting I should know when setting one up for TA?
myrxseven is offline
Old 01-13-2009, 05:35 PM
  #160
Trader Rating: 20 (100%+)
Hey guys i have a t2 007 that i want to turn into a trans am car. I am planning on running a tekin fx pro esc with a trinity co27. I can only run 4 cells correct? Whats a good gearing starting point. Spur/ pinion?
Also does anyone have a good starting setup for my t2 007, or will the set up i ran in asphalt touring last year be a good place to start
thanks for the help
CREWMAN is offline
Old 01-13-2009, 05:42 PM
  #161
I am routinely beaten by a xxx-s. I don't know anything about his setup except that it's dialed.
Old 01-13-2009, 06:03 PM
  #162
Kregger's Avatar
thanks for the help
Right you can only run 4 cell with that combo. Your asphalt set-up is a good place to start. As for gearing spur/pinion could'nt tell you its been a while since I ran a 007. check the USVTA web site under rules for FDR and you should be able to figure it out from there.
Kregger is offline
Old 01-13-2009, 06:16 PM
  #163
ok i guess its 31mm rims in the rear and 26 in the front
CREWMAN is offline
Old 01-13-2009, 07:38 PM
  #164
k_bojar's Avatar
Trader Rating: 30 (100%+)
that would be correct
where you planning on running trans am at??
k_bojar is offline
Old 01-14-2009, 06:49 AM
  #165
I think its just over 80 x 50, at least I'm pretty sure.
