XRAY T2’009
#1351
#1353
I'm trying to gear my 009 to a high bite med asphalt track running 17.5 Trinity with an SPX. I'm currently using a 112 with a 44 pinion with a FD of 4.33 using gearchart.com. Is this right? Can I gear down anymore. It seems that my meshing is real tight with the big pinion and can't seem to fit anymore. Is my Final Drive correct? Any suggestions?
#1354
Hi MACH55
I did a few mods to 96T 64P spur to get it to fit. You need to cut a few slots in the outer face so you get a driver to the rear motor screw.
This allows me to run from a 30T-42T pinion. This works out to be from mid 5s to high 3s for the FDR. You should find something in there that will work for the 17.5.
The spur was an AE one. The center hub was the correct thickness so it fits on the 009 center shaft without any mods.
#1355
with a spx on profile 7 you want to be geared in the high 3's
#1356
Problem is I can't seem to get it to fit without the meshing being real tight. Do I have to mod the bulkhead to get the correct gearing to fit? Is that the only way? If I put a 100 spur gear with a 44 will bring me down to sub 3's for Final drive but will it fit? Need some suggestions so I don't have to drill.
Thanks in advance!
Thanks in advance!
#1357
Thanks in advance!
Thanks in advance!
#1359
what are you running that you want sub 3's as your FDR?
#1361
I have no idea i dont run asphault, only carpet. What are you temping at after 6 min? It seems like being in the 3's would burn up your motor.
