XRAY T2’009
#1171
#1173
FK05 Lover: might i ask what thinner gauge plastic did you use to replace the spacer? just really curious
#1174
The dividers are 2/3rds the thickness of original part (no 305577) at 1.5mm compared to the divider plastic of 1mm
I use a divider (cheap) use the original part as a stencil, use a body reamer to make the centre hole & 3 holes around it, then cut the remainder with sharp scissors...takes about 3minutes
Hope this helps
#1175
Sure, I have an old plastic parts container with removable dividers,
Hope this helps
Hope this helps
#1178
I have a 008 and run a 009 main deck. Other than the battery being moved slightly forward and further out from the centerline of the chassis, along with the ability to run the fwd motor conversion, I felt that the 009 chassis made the car easier to drive/stable (less rotation in corners) over the 008 deck.
But this is my personal opinion.
#1179
If anyone has a pair of ECS driveshafts 50mm long I have a pair 52mm long I need to swap. They're brand new in bag, and I want yours to be likewise. Just bought the wrong length for my 007.
#1183
Hi mate,
#1185
Must haves:
009 main chassis
roll bar bars
Nice upgrades:
thinner topdeck
fwd motor kit
ECS cvds
narrow hexes
Other upgrades: (not required but nice)
alloy shocks
roll centre mounts (2+mm)
l/w axles and cvd bones
My car a month ago.
