XRAY T2’009
Old 05-21-2009, 03:41 PM
  #1141
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by dodgeguy
The asphalt top deck is different than the EU top deck. Here it is,
http://www.teamxray.com/teamxray/pro...Deck%20-%20Set
So I have the "EU" version, which comes optimised for Rubber tire/asphault racing... but it doesn't come with the asphault top deck? Something doesn't seem right here...
Cpt.America is offline
Old 05-21-2009, 03:46 PM
  #1142
Trader Rating: 208 (100%+)
The asphalt top deck is for very low traction tracks. Just another tuning option.
dodgeguy is offline
Old 05-21-2009, 03:56 PM
  #1143
I see.
Old 05-21-2009, 04:41 PM
  #1144
Skiddins's Avatar
I belive it was also released some time after the original cars debut.
Skiddins
Skiddins is offline
Old 05-21-2009, 04:55 PM
  #1145
I have another question for you guys... do you recommend using locktite on your chassis-to- bulkhead screws?
Old 05-21-2009, 05:09 PM
  #1146
Nexus Racing's Avatar
Nah, just use loctite on the universals...not needed on other areas of the car and could cause stripped screws.
Nexus Racing is offline
Old 05-21-2009, 05:15 PM
  #1147
Yeah, I loctited the set screws in my universal joints.... but how the heck could locktite cause one to strip a screw?
Old 05-21-2009, 05:57 PM
  #1148
jt415gz's Avatar
Trader Rating: 29 (100%+)
@ Nexus Racing,
I have the US foam spec and multi-diff...I wanna get the ECS drive shafts...what length do I get (50 or 52mm)? I think i read in the xray forums that an EU rubber spec w/multi-diff will need the US 50mm ECS as 52mm ECS will be too long coupled w/multi-diff in an EU...true or false?
jt415gz is offline
Old 05-21-2009, 09:08 PM
  #1149
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
If you thread lock the chassis screws then when you try and take it out it could strip. If you don't have a good wrench. Then you would have to call Billy Mays and get the easy extractor or whatever it is called.
Kraig is offline
Old 05-21-2009, 09:53 PM
  #1150
Trader Rating: 23 (100%+)
Originally Posted by jt415gz
@ Nexus Racing,
Could be true, always ran 50s on my foam car.
pcar951 is offline
Old 05-21-2009, 10:18 PM
  #1151
oh, you're talking stripping the head, not the threads... I see Thanks for the tip.
Old 05-21-2009, 10:21 PM
  #1152
bigkoitat's Avatar
Trader Rating: 6 (88%+)
I use blue threadlock that way it'll keep the screws from backing out, but somewhat easy to wrench out. red will be too agressive and causing the head to strip when trying to remove.
bigkoitat is offline
Old 05-22-2009, 04:18 AM
  #1153
rcterp's Avatar
Trader Rating: 35 (100%+)
If you can find it, look for Loctite 222. It's the purple compound that can be tough to find. It's specifically made for precise applications such as aluminum screws and screws under 4mm. It's perfect for RC, lighter duty then the blue and works great.
rcterp is offline
Old 05-22-2009, 07:53 AM
  #1154
I dunno.. the blu loctite I use is PRETTY light duty. It doesn't seem to really take any extra pressure to back out a screw... if just a tad. It just keeps it from vibrating loose.
Old 05-22-2009, 08:09 AM
  #1155
niznai's Avatar
In my experience the only time I found screws stuck in aluminium was when using a lot of buggy spray to clean the car of the annoying fluff it collects off the carpet. I think that promotes condensation on the chilled metal and if water gets in between aluminium and steel it is a very good chance corrosion will set in (as you will know from engines with alloy heads). Blue loctite is pretty weak but its main role for me is to keep the two metals somewhat separated so electrolysis is not initiated. Use sparingly though.
niznai is offline
