XRAY T2’009
#856
Flat, especially if you are getting the XRay lipo weights since it moves the battery out and the bumps will no longer fit in the slots. I'm scared of getting the Lipo weights because my car is pretty well balanced up front and the rear. But I may try them out.
#857
Well if you going to be running the lipo weights from xray they already going to hold the battery from moving side to side so you dont need the batteries with the bumps and remember that the new lipo weights are going to make the battery stick out of the chassis so i dont think you going to be able to use the batteries with bumps. Do they have those lipo weight for sell anywhere?
#859
#860
#861
Revo523-You will need to drop a lot of teeth if your not going to cut your tires like 30 to 32 pinion...I would cut the tires down to at least 58mm and you would run around a 36 pinion...Later Drew
#862
The Lipo weights should be shipping soon...Check the SMC packs out like the 24c 5200 and the new 28c 6000....I won the carpet nats with the 24c 5200...That pack is really good for 13.5 racing and its cheap like 79.99 in hobby shops....Later Drew
#869
I fitted the Eccentric holders recommended on the previous page;
302077
These actually make the belt a tad too loose but it's better than too tight.
Skiddins
#870
Your either very lucky or you normally have your belts too tight. If you can 'ping' them like an elastic band they are too tight as they will resonate at high speeds.
302077
Skiddins
302077
Skiddins
After my first run last night with the fwd motor conversion all belts have stretched even more and they needed to be tightened up (mod/lipo/asphalt).
