XRAY T2’009
Old 05-14-2010, 09:42 PM
  #2356
Originally Posted by MatsNorway
Does anyone know of a good web page that sells xray parts?
I need part: 305005 or 305000, 305001, 305002.
I got a T1.
http://www.rc-mushroom.com/index.php?cPath=36_263
RCmart
http://www.teamxray.com/xshop
ebay (UK & US)
some T2 parts fit
305002: Complete ball diff: Thats gonna be expensive, no matter where you buy (now 'superseded' : check the xray site)
Same with diff output shafts $$$$
1101 is offline
Old 05-15-2010, 03:39 AM
  #2357
http://www.modellbil.no/shop/product...ducts_id=20774
Part 305005 is at a ok price. but it looks like its open so dirt can get in to the greasy stuff.
anyone knows?
MatsNorway is offline
Old 05-18-2010, 11:25 AM
  #2358
helo?
Old 05-18-2010, 11:34 AM
  #2359
Dane's Avatar
Trader Rating: 26 (100%+)
helo?
Just don't go nuts on the diff grease. Easy as that.
Dane is offline
Old 05-19-2010, 02:08 PM
  #2360
I just bought a used 009t2.I just noticed in the instr. manual that the rubber edition takes one kind of a-arm ,and the carpet car another..'
"I am supposed to have the rubber spec edition" .What should be stamped on the a-arms?And what is the difference in te 2?Can the car run with different types of a-arms.?Would the car handle different with foam spec arms on a rubber spec car?This car has an X and an H stamped on each arm.But the stamped letters are on different places on each arm it seems.
regards
tc3jp is offline
Old 05-19-2010, 03:04 PM
  #2361
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I believe the rubber car uses the (H)ard arms, and the foam car uses (X)tra hard arms. The arms are geometrically the same but one uses a harder plastic than the other. You will want to run the same left to right on the car... preferrably front to back as well.
Cpt.America is offline
Old 05-19-2010, 03:11 PM
  #2362
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
Anyone know if the Exotek chassis for the 08/09 includes the extra bulkhead mounting holes for the motor forward conversion?
-rocky b
flatspunout is offline
Old 05-19-2010, 03:27 PM
  #2363
-rocky b
I dont run the forward conversion.. but im pretty sure it does. i can look at it later when i get home.
Old 05-19-2010, 05:19 PM
  #2364
Abu Salahuddin's Avatar
regards
Apart from the suspension arms, there are a couple of things that are different too. This include thickness of lower deck chassis, teeth in the pulley, and harder material for axle hub. Basically a carpet chassis is designed to be stiffer that the rubber spec chassis. You can you this chassis for asphalt but will not be very responsive especially if it is a technical course.
Abu Salahuddin is offline
Old 05-19-2010, 06:05 PM
  #2365
From the information I have gathered, I have the rubber spec car.It has the 2.5 lower chassis and the right upper deck.The only thing I can see wrong are the a-arms.Three of the arms have XH stamped on them, and one has just an H stapmed on it.Is this going to throw things that far out wack..,.I will certainly be back with more questions as I find more things wrong with the car.
tc3jp is offline
Old 05-19-2010, 08:12 PM
  #2366
Depends on your level. It will only make the TINIEST bit of difference if you are at the level where you push the car hard enough to make the arms themselves flex. I would replace the one H arm, with an XH arm, just so the car is even. The vast majority of what makes the rubber car flex more than the foam car, is the chassis, top deck, and how many screws you use for the bulkheads and topdeck.... you're fine.
Old 05-20-2010, 01:51 AM
  #2367
There is a picture of the bottom on the website I didn't see before and it does have the extra holes. Thanks
rocky b
Old 05-20-2010, 03:10 AM
  #2368
Is that a yes its open and are you sure?
Old 05-20-2010, 06:28 PM
  #2369
snowman_evil's Avatar
Trader Rating: 30 (100%+)
Can you run the Spec R gear diff in the t2 009?
http://www.egrracing.com/shop/gear-d...8t-p-3825.html
it says it fits the T3 but doesn't mention the t2 009.
And also if you can use the 38t gear diff, can you run it with the 20t standard centre pulley if you change the rear belt??
Thanks in advance
snowman_evil is offline
Old 05-20-2010, 09:55 PM
  #2370
I am getting an ungodly vibration when I turn the wheels right or left.
Someone said the "ecs" parts will fix this .
Searching Nexes racing, I came up with two options, part number: "305277" and part number:"305327" which ones do I need? and do I just need them for the front to solve this problem.A guy at the track had this same problem with his T-3 and he replaced them with the ecs parts.I saw him go full throttle while turning right and left and it was as smooth as glass,but I did not notice if he had them on the rear.I saw them on the front though.
tc3jp is offline
