Lipos on XXX4, will they fit?
Will Lipo packs like maxamps 7.4v fit on the slotted chassis (for nimh cells) of the Losi XXX4?
Thanks in advance.
Thanks in advance.
I run Orion 5000 packs and as the others said, I ground down the nubs on the chassis so it would fit and flipped the brace over to the flat side. I also added a side block so that the pack wouldn't slide out of the side. I saw it happen to another racer a few times and then it happened to me once.
I probably should add weight to the battery side, but honestly I haven't noticed any performance problems without doing so.
Jerome
Jerome
