battery help
its a ready to run lrp esc, forward, reverse, works fine
and its an epic x stock brushed motor
So have you changed the spur? I believe stock spur on a t4 should be 87 tooth. If you are in fact running a 81 or 83 you may already be over geared. Has the motor been getting too warm? Take a look at the brushes. If they are kind of dark and purple on the end that makes contact with the comm you have been running it too hot. If they look good go ahead and step up to the 7 cell, but step down 1 or 2 teeth on the pinion and do some testing. If after running for a few minutes the motor is cool go ahead and step back up.
By the way....Just noticed your username. Is this Niggles from the Des Moines area?
hi, i bought a 5000 mah nimh 7 cell from cheapbatterypacks.com and it has only 2 cyles on it
the power is great, but it only lasts about 5 minutes and then it just dumps
is this just because its new or is there a problem with my charger or the pack? it goes from full power to barely any power
its also only takin 12 minutes to charge on 5 amps
#20
yeah thats me
well ive already ran it lol,
but i think its a 83 tooth spur
i'm goin to go out to haven tomarrow to get a pinion, which one?
also maybee a 87 tooth
either this battery or charger is wierd, or its just me
one run it will have more power than others, i think its my charger, gonna try a buddies tomarrow
so what temp should the motor be?
#21
i think i'm goin to get new brushes, a 87 tooth and a new pinion what pinion?
i'm thinkin like 18 tooth or less?
#22
With a stock spur on a T4 the rule of thumb would be to start with a pinion that roughly matches the turns of your brushed motor (double for brushless). If you 'tre running a 19T, start with a 19T or 20T pinion, for a 15T, use a 15-17T pinion.
I would try charging your LiPo at lower than 1C. That charger can only charge at up to 5 amps max, so its at its limit and will likely false peak unless you use a DC power source. I've had better luck at 4.5 amps when using AC power. The vision peak ultra doesn't read total charge, instead it offers total time (minutes) of charging as its measurement.
Also, make sure you have used the yellow button to select LiPo as the battery type. It's not spmart enough to know the difference, so will attempt to charge it as a NiMH or NiCd if that's what's selected. Neither of those choices will properly charge a LiPo as the LiPo charge sequence drops the amperage toward the end of the cycle repeatedly until the pack is completely full.
