Can tire warmers "melt" glue?
I've been told that tire warmers can make the glue soft, is that true? It should be a problem with unregulated tire warmers???
Originally posted by Randman
That shouldn't be a problem at all, the tires heat up when you run the car anyway, all tire warmers do is get them up to temp faster.
I think the melting point of the glue is alot hoter then when you run it or put the warmer on. I used to take offroad tores offf in the oven and then had to be preaty hot for the glue to crystalize or come off
