Talkin' with Josh Cyrul
#361
Originally posted by Josh Cyrul
Fike - In mod I've been running those front tires along with either Double Pink or Purple rear tires (JACO). The tire combination that you are using might be the main problem.
What's the rating of dbl pink?
Thanks again...
Eric
#362
Everyone ready for the news!!! Here it is!!
3-Time IFMAR World Champion David Spashett has also left Trinity! He will still be in Cleveland this year with his Team Orion powered Losi XXX-S as well as his new CEFX 1/12 car!! I'm proud to say that David will be CEFX's first official sponsored driver (I don't count - I own the place!!). Now, let the fun begin!!
#363
Trader Rating: 13 (100%+)
Looks like an exodus.
Whats a CEFX 1/12?
Whats a CEFX 1/12?
#366
John - Thanks!!
Mike - Wow is right!! Walter land was fun!! It was cool to see that my TC worked well with the same set-up at a few different tracks now!!
Ray - That's the same thing I've found!!
roll-tide - I used my Losi rear tower but the hole location I used is nearly identical to the outer hole.... As far as the set-up, I've always run a softer shock set-up than most. I use the camber links and droop to help control the roll...
Fike - Double Pink is about a 35 shore tire - about like a Magenta...
#368
does that mean I should hold off geting the new trinity 1/12?
#370
Josh-youve got it going on now!!!
What brand Diffs are in your Tc3 and how often do you rebuild them?
do you replace diff balls, rings and thrust washer assy-or just relube and rebuild?
I ran Mod for the first time and my new front diff needs rebuilt after only two runs!! It still works, but so gritty. My diffs usually last all season in stock!!!Thanks as always for aswering all my questions!!
#371
R/C Tech Founder
Josh, now you need to get David to come here as well
#374
I would say that you count Josh, but maybe a half.
see you next weekend,?
from the person that isn't dedicated enough
