1/10 R/C F1's...Pics, Discussions, Whatever...
We need Tamiya to re-release the sparking diffusers they used to sell for the F101 and F102.
Not recommended for carpet.
Thank you guys for the links Just a quick question, if I went with one of those ebay lights, would I be soldering directly to the +- terminals on my ESC? Similar to how the BEC is attached?
Depending which voltage you buy. 5 or 6v version can be put into a free channel of the receiver by adding a servo plug and the 9v version can be connected to the battery wires.
You can also get the led only:
50pcs 5mm Red Diffused Round Self Flash Flashing LED Blink Bright Leds Light New | eBay
And determ the right resistor and connect it with a servo wire.
Here are three pics of my recently completed WRC F-one
what wheels are those
I allready got a good hint:
RW Racing go below 60T 48dp for pan car spurs
available here
Demon Power Products - Servicing Radio Control Cars Since 1978 - 01252 343132 down at bottom of the page
available here
So I found and bought those: 66t, 60t, 58t (all 48p)
Didn't receive the stuff yet but might post a picture as soon as I got it going!
WRC P-one:
Do these spurs carry a center bearing?
No, they don't, you need a spacer to fit them, Tamiya 54215.
Hugo
Hugo
Does anyone have info info on the following Ride tyres
#26040: GR F-1 fronts
#26041: GR-X F-1 fronts
#26042: GR F-1 rears
The Ride site has them as high grip tyres so does this mean they are pretty much same as the 26030 and 26031 preglued?
I was racing on the weekend and was swapping between the 26030/26031 Rides and Pits. Frustrating having to adjust ride height for every change of brand.
Hoping these are a grippier version of original Rides which will make swapping tyres a much easier process.
