1/10 R/C F1's...Pics, Discussions, Whatever...
#3121
Scale factor, although correct, does not change the fact that alot of racers have already invested in those 190mm+ cars. So should they throw their cars in the garbage ?
#3122
What "scale," whose scale, who made up that width, what real road or race cars have exactly the same width, and doesn't real F1 change their scale or specs and their appearance and tire requirements depending on Bernie's mood literally every year?
#3123
Hehehehehe but it gives you a better control of the car.
More flex at the rear and better handling.
What i said before.
I did drive them head to head and they are almost identical.
The F104W is just a bit heavier then the F103.
This is why the F104 is just an tiny bit slower in the same config as the F103.
If i put the same amount of alloy on the F103 it would do the same laptimes.
regards Roy
What i said before.
regards Roy
#3124
The line has got to be drawn somewhere...no matter where that is there will be people who will not be happy with it. 2 classes would be great...if there were enough racers to support it...but we already have too much class dilution due to too many on-road classes in general.
#3125
I ran 200mm against 235mm cars as well when I ran the HPI 10GW pan car...my 235mm car had a significant advantage over my 200mm car. If I could have got parts support for my EV10 I would have gone back to it...unfortunately it wasn't long after that that pan car racing died out completely in my area so I was never able to go back to 235mm.
#3127
I think with rubber tires, width becomes a non-issue. Has anyone with an F103 gone faster than F104 on rubber?
#3129
A lot of racers have also bought 180mm F104's, Tech racing 180mm cars, and converted F109s...should they start throwing their cars in the garbage and buying 200mm cars when they start getting spanked by 200mm cars that don't look scale?
#3131
If F1 racers were forced to switch chassis it was from 200mm down, not the other way around. 180mm cars came after the 200mm f103's , so you can't come with that argument ! If the 200mm class died out it's because the manufacturers started making 180mm cars out of the scale factor excuse, but we know it's really because of their bottomline ! Not all the racers wanted to switch from 200mm to 180mm, the same way no one wants to go from 180mm to 190mm now. You are right that someone has to draw the line somewhere, and that person has always been the manufacturers defending their bottomline, even if that means ignoring the racers. Hopefully they will learn from their mistakes, and listen more to the racers...
#3132
I think it is possible to make an adapter to go from pan type screws to tamiya hexes...
#3134
It's also possible to reduce the width of the pan car with the adapters sporting shorter tamiya rear rubber tires, and come up with shorter A arms for the front suspension to make the pan car chassis legal...I am sure it will be most welcomed by F1 pan chassis owners who wish to participate..
#3135
Like it or not...Tamiya drives the F1 market and other manufacturers just follow along. Why is it that Tamiya is the one successful at doing this? Do they make the best chassis? Not hardly...they make the most realistic car and body combination out there and that is what attracts people to the class. Like Slash, VTA, and RCGT, one of the biggest (if not the biggest) factor in bringing people into the class is the scale realism. And the most scale looking cars to current F1s are the 180mm cars. I love my F103s but I saw the writing on the wall a long time ago and made the switch.
