Fastest Driving Style.
This is something I have flip flopped between myself and am wondering what others have found to be the better way to go.
- Point and shoot
- Easy on and off throttle.
How much of a factor is surface?
How much of a factor is car setup?
Full scale its about carrying speed.
Is that the case with this sport?
And yes , I realize I may be opening a huge can of worms .
Factory opinions welcome.
Dave.
- Point and shoot
Dave.
- Point and shoot
Dave.
- Point and shoot
Dave.
having raced off-road electric/gas and TC electric/gas I've found that being as smooth as possible is typically the best choice.
Granted, each discipline has it's own requirements and dos and donts...start with a smooth input, slow in and fast out, largest radius is the fastest way through a corner and give yourself a few inches from the pipe until you build up your skills.
I may catch flack but IMO
Faster Through the corner is faster around the track.
Very Important for fast open tracks where coming off the corner slow could be the difference of being able to pass someone on the straight or just staying behind them. Loosing corner speed will also make the motor work harder which will just lead to issues with run-time, fade, and heat when you continue to gear the car to be as fast as the others.
This is my exception. Not all tracks have flowing drive lines and the smaller the track, the more driving style will head towards Point-and-Shoot. It may just end up that only one section of corners is Point-and-shoot while the rest is all about driving smooth.
The more power you have, the more you can benefit for taking a shorter line (=point and shoot) vs. drawing a nice flowing radius. If you watch fast guys run modified, they are very much point and shoot around the slower corners. On the fast flowing sections, where you are not overpowered in relation to the speed you're doing, of course keeping up the speed is important.
When running stock, you don't have the punch out of corners and there keeping up the speed is more important.
Suspended
Fastest Driving Style = not hitting anything
it seems like the guys that ask this question are the ones that have yet to figure out that the fast guys get through entire heats without single wreck, where as the not-as-fast guys you can tell where they are on the track by all the whacking and banging
Or, alternatively, buy a ridiculously fast brushless set-up and hope your going so fast you'll go right through the walls and appear out the other side of the track.
I think that setup is critical in electric tc racing but as far as driving style goes I think it all depends on what works for the specific track, driver, and car. IMO most people can drive their car just fine but the next guy's car is a completely different beast.
Ie... recent meet I was at had a hairpin on and off the main straight. Due to the open nature of the track the spec classes were driving a big sweeping line through the hairpin onto the straight. Mod however drove straight to the apex, stopped hard and stay tight, the hammered out of the turn with crazy lipo/4.0 power. The mod guys had enough power to more than make up for their lower mid corner speed.
Spot on. The method of taking any corner is to maximise you speed on the open sections. Therefore your horsepower and the type of corner is what decides the way you take it.
Suspended
