Mi 3.5pro
hi next instalment
wentback to ware herts last night (tyres sweep32s)
(trying to stop the grip roll)
changes from last week were
1.2 rear roll bar
shocks 1.1mm hpi pistons
ft 60 wt hpi pink
rear 55wt hpi blue
car not grip rolling in pratise went from pf mazda speed 6 to eastcoat speed 6 car alot better
1st run
on high speed corners car starts to dig in scrubing speed off back end trying to come around
if you 1/2 throttle easing off it will go throu ok but you loose time really needed the car to hold the speed
2nd run stood ft shocks up to outside hole
still doing it slightly better but a bit more violent when it did try to let go but could hold on to it
3rd run put 1.6 ft rollbar on still there car now would let go then started to jump about i thought tyre had come of turned out to be a screw from bottom chassis marshell quickly took it out
car then felt good i started to push hard but i was still doing it had only had about 90 secs this run decide to leave the same for final
final a7
car same would let go at the corner
ok if you come off the power as you hit the apex then fed the throttle easy back up to full finished a6
any ideas???????????
1.2 rear roll bar
ft 60 wt hpi pink
rear 55wt hpi blue
1st run
final a7
Super Moderator
Its really nice for novices because the cars are put together right. No matter how good the instructions are on any car some guys ALWAYS mess up the assembly. The Mi3.5 at least get guys off to a good start.
That said, no one builds a car like I do so when I get my 3.5 it is getting taken a part completely
#20
What Turn Motor Would you suggest for the MI3.5 pro
