Tamiya TB-02
#1086
Hi guys looking to get a tb-02
but i've read before that pinions and spurs are restricted so are the choice of gear ratios? is this true? if so may i ask whats the highest and lowest gearing you can go please?
also with the front one way, you have to buy the evo 3 one way right?
thanks in advance to all comments
cheers
cheers
#1087
cheers
cheers
highest is 9.90 using 61 spur and 16 pinion
#1089
pinions
Actually I have a 28 tooth pinion and I hear you can get up to a 34 and yes it is Tamiya.
#1091
Pinions
Westedude, The ratio they are refering to is the corse gears .6 module. similar to 48 pitch. I think the ones you are talking of are the .4 gears similar to 64 pitch, and I'm pretty sure you can get them up to 51 teeth.
#1092
Pinions
I'm not certain and I'm still learning the car, but the 28 I have is almost identical to the 27 I'm currently running. If dsrlbtoys is out there he knows a lot better than I do, but I mine is a Tamiya gear.
#1093
westerdude,
what size spur are you running?
#1094
Originally posted by RC Driver Gary
Eeeeeeeeexxxxxxsellent Smithers I wondered when I saw that event added to the schedule if it was indoor or outdoor since April in the Midwest can be really nice or really chilly
#1095
Originally posted by rayhuang
Well-what a suprise I got today. I took out my tb02 for my first sedan rubber tire experience. I expcted to slip an slide and push out the door-and I actually traction rolled the car!!! I guess its time to stiffen up the shocks. I still need HELP on a set-up-any set-up. SOmeones got to know something!!
