got a question about overheating
I got a T maxx with a 2.5R and its had about a gallon or so of fuel ran thru it since break in, and the last couple times that I've ran it, its been running strong for about five mins or so and then starts to bog and slowly bogs so much that there is almost nothing there for throttle, also starts to overheat after boggin. Now its never done this before, I clean the air cleaner air filter after every run and try to keep a strong glow plug in it. Plus I've never raced this motor. could this be a fuel mixture issue? cause I've tried to richen and lean the mixture to try to fix the problem. any suggestions?
sounds like an air leak..
are there any spots on the engine what are wet with fuel?
sounds like my os rg does it die after you start it an go
