What is the penalty for not marshalling?
Was at a race event yesterday where the fastest driver won convincingly in the first two A-mains (1st and 1st) so he sat out the third one, and then stupidly neglected his turn marshall duties. There was some trackside talk about him possibly losing all the points from one of his best mains, but in the end, the race organisers concluded he was still the overall winner.
What are the rules for this at the big events where you guys are?
Suspended
At CVR down in Madera, California your penalty depends on what race you failed to marshal in.
If you fail to corner you will loose a lap from your best Qualifier
If you fail to corner after your Main you will loose 2 points on Points Race days.
If you leave and fail to turn marshal twice you will be banned from the track for one month.
If you fail to corner in None Points Main Events you will be placed last in your Main (points race)
Losing 2 points would be equivalent to dropping 1 position for that particular main, right?
Should be a total DQ!
Turn marshalling is a serious issue at every track and needs to be dealt with harshly!
A good kick in the AZZ !!!.....To marshal is fun for me as you get the ring side seat and you see how other buggys perform on the turns and jumps.
It allso shows that you are not too proud to help out and pick up a few cars !!!
Timmey
Timmey
Marshalling is the penalty for racing. He missed the heat, he shouldn't have to marshall.....in my opinion....however, for the main, that is a different story. It really depends on the track. I think that 7 marshalls can do as good of job as 8, but I suppose if there are 3 or 4 in the heat, it would be a big problem.
