Best brushless
Best brushless
Is the Mamba or the Velineon better? If i were going to get it, i would be putting it in a slash. With lipo. Also which would be the best kv rating of mamba motors. OR should i jsut go with the Mamba ESC and Velineon motor? i heard that was a good combo. LMK
I don't have much experience with the Velineons, but I can attest to Mamba Maxs. Castle Creations make some really good, no-bullshit products! I personally use the 5700Kv + MM combo, but I wish I bought the 4600Kv motor instead... Having too much power works against you...
i run the velineon with sidewinder combo. the only reason i went that route was cause i wanted a 35ookv rating that castle doesnt offer. i didnt want the speed due to the track i run is small and technical, but the torque is nice. barly have to pin the throttle to get over major jumps.
Go mamba over velineon anyday. Only problem is that the smallest mamba 1/10 motor is 4800kv, but if I had the choice of all 1/10 combos I would go with the Tekin R1 Pro/Redline Combo. There is alot of redline kv motors availiable to
9,000 kV 7,800 kV 6,800 kV 6,200 kV 5,800 kV 4,800 kV 3,700 kV 3,200 kV
http://www.teamtekin.com/blmotors.html#redline
Amainhobbies seems to be the cheapest place to get them
http://www.amainhobbies.com/index.ph...cturers_id=276
Suspended
I run on my practice losi xxxcr buggy a Excelerion 6400 system geared @ 23/78 i'll take any help with the gearing though! Actually was thinking about running mod with this!had it out front of the house today and it was pulling wheelies ten feet after it started the run, holy chit almost back flipped a few times!
My pro-stock buggy has an LRP Sphere 07 comp 13.5.My wheeler has a GTB w/6.5 motor!
Regional Moderator
Do you want a light switch speed control that does lot's of wheelies and is good for running up and down the street or do you want a competition ready speed control with tunability for track conditions.
If you want to race and be in control go with the Tekin.
If you want wheelies and wheelspin go with the others mentioned.
