d5 flat liner
d5 flat liner
Hi there,
I am racing factory team tc3 and run ti 10x1 motor tryed d5 10x2
flat liner and can't get the rear tires not to spin out when getting
on the juice I run 100x32 in 64 pitch what can Ido to get better
traction?
also where can I get a warpspeed chasis for me tc3?
traction?
Re: d5 flat liner
Re: d5 flat liner
[B]Hi there,
traction?
/B]
[B]Hi there,
traction?
/B]
2. Softer, stickier tires.
3. Adjust your rear suspension, by using softer springs/oils.
Wheel spinning! That's the whole point of a hot mod motor, isn't? )
I have the softest spring now have my shocks layed down and am running 30wt.The problem I have is every time I make left
turns the car just does tight donunts or is super loose
I have another tc3 and it drives like a dream with a10x1 and
32x100 gearing set up the same way as the trouble car.the
only differecne is the motor I would like to take advantage of the d5 power but can't get to work?
Also what is a good gear ratio for the d5 in an open track with
smooth turns.
smooth turns.
Check your diff, it might be too loose?
zzcutter wrote: The problem I have is every time I make left turns the car just does tight donunts or is super loose
thanks guys will check it out
HeY!!!
zzcutter first befor you take apart the car just try and balence out the weight and then if that don't work take it apart and see if chassis is liftin in a corner or what ever.
