kyosho Inferno ST US Sports factory settings
i need help my idot brother in law started messing with the setting on my carb and i cant find my manual for the factory settings . anyone now where i can find them. the car is not starting and if i do start it its running to hot and out of control .
here are the truggies specs
Shaft-driven 4WD with a long-wheelbase chassis and ultra-long suspension arms.
Equipped with an easy-start high-power GXR28 engine with one-way bearingless pull starter.
Front and rear diffs use machined, hardened steel spiral ring and pinion gears.
Teflon clutch shoes.
Hardened clutch bell and spur gear.
Set the end-points etc with the multifunctional Perfex 14 digital transmitter with LCD display, 12 model memory, end-point adjustment, digital sub-trim and more.
Body comes complete with unique color scheme.
Factory-assembled chassis shares the same tough characteristics and low center of gravity as the World Championship winning Inferno 777.
Includes hand-welded manifold and tuned muffler.
Full ball bearings throughout for maximum efficiency through the drive system.
Long suspension arms provide tons of travel and a super wide stance.
Compatible with many INFERNO ST-R standard and option parts.
ReadySet Contents
Factory assembled chassis with pre-adjusted linkages
Special manifold and muffler
Pre-painted with stickers pre-attached on completed body
Pre-Installed Perfex KT-14/2-ch 2-servo (KS-1401 servo spec.)
Pre-installed GXR28 engine with recoil starter
Plug heater
Fuel bottle
` - Cross wrench
ReadySet Contents
Plug heater
Fuel bottle
` - Cross wrench
