SANWA M11S 2.4G Limited
SANWA
M11S 2.4G Limited ( faster 30% )
- Switch liquid crystal of two large-scale dot matrix liquid crystal CMF display * colors backlight LED * Raundosticc
- Stick tension adjuster 30 model of * key assign function * memory * vibrator function
- TWEAK function * Ecsponenshal * adjustable rate control * anti lock brake
- Traction control * throttle holding * Brakimishing * C-MIX * servo monitor
- Direct servo control * key lock function
Package including :
M11S Transmitter x1
TM-221DA 2.4GHz RF Module x1
RX-442DS 2.4GHz Receiver x1
TX-Battery x1
CHARGER X1
DSC CABLE X1
http://rcmarket.com.hk/product_info....oducts_id=4540
Package including :
M11S Transmitter x1
TX-Battery x1
CHARGER X1
DSC CABLE X1
Engrish?
i was under the impression that it was a Euro / Jap relese only with sanwa... saw it a while back at some TC race
booo! the antenna is still on the module.
Simple question, did anyone meet any Receiver shut down due to overheating with this TX/RX ?
I'm about to sell my 3PK so I would like to know before buying somehting else.
Thanks a lot.
Slide
Thanks a lot.
Slide
binding problem ??? ...
hi guys, just a quick question. i have just bought a 2nd sanwa receiver, unfortunately they shipped me the Sanwa RX-442DS reciever instead of the RX441DS receiver.
can i bind the transmitter TM-221DS with the 2nd new receiver RX-442DS (not RX-441DS) ? i am having trouble binding...
i am using the sanwa M8 trasmitter, my first set is working fine (TM-221DS & RX-441DS).
please help thanks in advance !
Hi Bad Mika,
You can try use the RX-442DS on "static" first and see what happens.
But I've been told that the RX-442DS is new receiver able to work with the new tx module from the M11"S" only. So I doubt it could work fine with the TM-221DS.
So try static first and if it doesn't work clearly, you will just have to send it back to where you get it.
Hope it will help you.
Cheers
Slide
Cheers
Slide
Hi Bad Mika,
Cheers
Slide
Cheers
Slide
Thanks for the advice... Just one question, what do you mean by 'static' ? ...
I have the TM-221DS/RX-441DS and the RX-442DS...
Thanks,
Best Regards
Mika
Sorry,
I mean you should try your current TX (the TM-221DS) with the RX-442DS on the car while its wheels are not touching the ground first to avoid any trouble.
According to my infos, the RX-442DS would not be compatible with the TM-221DS because this new receiver hasen't the same 2.4GHz signal.
It fits with the new M11"S" limited only (which inluded the new TM-221DA module).
Cheers
Slide
Cheers
Slide
hi... is it possible to purchase the receiver top cover? mine is cracked but works flawlessly. This is for the M11 2.4GHz receiver.
thanks!
thanks!
Registered User
Ok, so i just bought a brand new M11 Airtronics the other day and i was having the worst time binding it i was about ready to throw the gosh darn thing out the window... BUT i found out that it is a 3 channel receiver... well i can only use a 2 channel or a 4 channel, please correct me if i'm wrong, so now i have to go back to the store and gotta either trade the receivers out..hopefully this will help someone if they are having troubles binding.. but please correct me if i am wrong because i can't change the transmitter to channel 3 but i don't know if this receiver is compatible...help?
Good job discovering this after you bought it.
I can't possibly see how this would help anyone.
How are we to know what receiver you speak of? I am sure many people will be offering you great advice in response to your well thought out and concise post.
Registered User
Well sorry for the confusing post but i am using it for a remote control car which is a associated RC8T. I didn't get to see everything when i purchased it. The receiver is model AIR92324. I can't get it to bind at all. I believe it is the wrong receiver for this transmitter, but I'm not sure. Any help is greatly appreciated.
That receiver model is for the mx-3 FHSS radio. I don't know if it's compatible with the M11 FHSS-2, or FHSS transmitter modules. What transmitter do you have? Did you buy your radio new? Is this the receiver that came with it?
