Any tricks to removing a siezed carb?..
yep...I can't get it out.......
interesting that you've had the problem ONLY with RB...
I wonder if they use a different compund in the casing and/or carb....
Anyone else have that problem with just RB's...
any other solutions?....Cause none are working so far..
heres RODY's answer to the problem..
That the carburetor of the .12 engines can get stuck into the crankcase is indeed possible, however this problem is increased due to the overtightening of the fixing nut of the carburetor.
If you tighten the fixing nut of the carburetor too much, you can create a burr at the neck of the carburetor which is inside the crankcase.
This burr then makes the aluminium solder itself and so it gets stuck.
The only way to get this out, is to spray some WD40(or some other very thin oil) at the fixed parts, heat-up the crankcase and then try to get it loose.
On the new V-Series .12 engines we have increased the diameter of the pin and nut, so there is more surface to lock the carburetor and normally there should be less problems.
However with this system when you overtighten the nut you can still damage the neck of the carburetor, so please be carefull.
and I guess there is a problem...and the nut WAS NOT overtightened......
And I guess ALL you guys did the same thing....
nice...I now own 3 RB paperweights...
these will be my last ones.....
Easy Bake Oven
Hey Harry, could you throw me a couple of pieces of pepperoni pie it there. 450 deg. for five to six minutes ought to do. I'll stop by with the beer and we'll talk rc.
Good luck
John
Good luck
John
Re: Any tricks to removing a siezed carb?..
Originally posted by fastharry
My RB,bless its PIA heart,has the carb stuck...I simply can only turn it about 2 mm...thats it...I tried heating it,no good...
Soaking it..nope..
I need to get it out of its bore..any ideas on how?...
also,how to prevent again?...
Thanks..
Soaking it..nope..
Thanks..
To do not destroy case *(carb is gone already), you need very carefully take all internals from carb case and cut carb body piece by piece using side cutters. if you will try to move it more it will grab more-all soft Al alloys acting he same, to prevent it-before install it, just down size it with sand paper little bit and use nikkel antysieze by "loctite" (works great).
#20
if you tried everything under the moon, you might just have to get another engine. Goodluck and let us know the status if you get that carb off.
