eZRUN brushless system
#796
I bash with slicks all the time, there's nothing wrong with using them for bashing. The cool thing is since they're slicks when they get worn they still offer the same feel unlike treaded tires which when worn turn into slicks which changes the grip level.
#797
#798
You MUST use inserts to hold the tire up & glue the tire to the rim (CA glue)
Or buy some preglued tires
#799
When you using foam inserts on the HPI when they were ballooning?
What does the different # mean beside the tire?
What about when bashing and the parking lot has a lot of small pebbles aren't patterned better?
#800
yeah, u have to have the foam inserts. with good glue id imagine they would balloon more on the inside than outside. but then for bashing ballooning isnt really a big deal.
#801
Inserts hold up the tyre, like a car/bike innertube
Perhaps heavy treaded/offroad-rally tyre may be better for you, it sounds pretty rough where you are going to run ...
#802
#803
So i don't know what tires you get someone on here was saying the HPI ones on here ballooned on them, I will be bashing on asphalt that might sometimes have small pebbles so what should i get? Also what does the number mean beside the tire?
#804
so the 9t is the lowest the 35a ESC can handle right?
#805
#806
my FDR is around 6. i think im gonna want more speed once i get this in.
#807
#808
ima basher the next thing speed wise would be 11.1v lipos. cant go with smaller gearing cause the belt on my sprint 2 is already rubbing the can.
#809
eZrun with KO Helios
Hi all,
I have a new eZrun combo and I try to recalibrate and use it with my KO Helios Ex-10. There is no problem with braking and going backward but with going forward, the flash leds on esc keep flashing both green and red and it stands still, after a delay, it punches. It's like a delay time before going forward. Do you guys know why is that?
Thank you very much!
Shen
Shen
#810
Hi all,
Shen
Shen
