eZRUN brushless system
#376
HI all, I M new to EP, don know much about the electronics needed to run these Ep cars. Can someone shed some light for me. I have a NANDA NRX18, which of the Hobbywing brushless ESC/motor combo suitable for this car. we have a small technical track. and which one is suitable to be fitted into the ABC M-Chassis car?
because you can more bl motor choice !
#377
nah, any more than a 9t in a mini will be mad.
#378
New problem I can't figure out. I am trying to set the drag brake but no matter if I set the drag brake setting at 0 or 40% it does the same nothing. I have the brake force set at 75% I tried it at 100 and it just locked up to much for me. All the other settings I program thru the program card work fine but I can't get the drag brake right. What could I be doing wrong.
#379
ESC Timing
Has any of you guys mess with the ESC timing? What does it do actually? Is it really working? Its for EZrun 60A with 5.5T combo.
#381
#382
I changed the timing on my esc. I am running a Novak 10.5 with 60A esc. Before I upped the timing it seemed like it didn't have any real power. After I changed the timing it had all the get up and go I needed. The only thing to make sure is that the esc is not getting hot when you change the timing. I had to go up a pinion size to keep it cool.
#383
Hey guys... Im thinking of buying a ezRUN Brushless system since its way cheaper than the rest. My question is, what is the difference between this brushless sytem and the rest? Is the KV rating lower than the other motors with the same turns? What is the KV rating anyway? Can someone please shed me some light.
#384
#385
I just bought a 3racing heat sink with fan for my motor. Question is can I just solder the fan wires to the ESC's fan wires together? The heat sink fan rated at 7.2V. Will this affect anything especially the ESC's performance? I want to do this coz the wires are short and they can only reach the ESC easily hence nearer.
#386
you can solder then onto the INPUT wires to the ESC... so it's basically connected to the batt pack even when esc is turned off.
Paul
#387
#388
Thanks guys!
#389
Hi,
Anyone has tested the 60A esc with a speed passion, orion vortex or any similar sensored motor? thanks
#390
My dad is having a problem with his 35 amp and 3000kv motor. It is massive cogging un-drivable, He changed drag break and test it was fine 5 mins later he went out and now he suspects it is dead, should I just buy a new one? Fix it?
I will ask cannon for a discount for another one cause he is a very nice guy
