Lipo Balancer
Lipo Balancer
Looking for a balancer but there are so many out there . What separates a good balancer from a bad one . Don`t have a lot of $ right now so I can`t spend a lot . for right now looking for $40 and under . Seen some from $5 to over $100 .
I obtained the lipo update for my GFX but it does not incorporate a balancer with the charger in the update.
Thanks for posting the question. This will be my next purchase.
Lipo Balancers are pretty universal so if the voltage or number of cells falls within range then it is a matter of getting the right plugs/connections.
All balancers should do the job.
commonsense makes a balance pro which has a voltage meter built in to it, this is a very easy to use balancer and also trakpower v-balancer is easy also. What type of lipo cells are you using?
http://www.BulldawgRC.com
here are some good balancers
http://www3.towerhobbies.com/cgi-bin...&I=LXMGS7&P=ML
http://www3.towerhobbies.com/cgi-bin...&I=LXTSA5&P=ML
http://www3.towerhobbies.com/cgi-bin...?&I=LXRWF8&P=7
this last one is passive (i.e. dischager balance only)
http://www3.towerhobbies.com/cgi-bin...?&I=LXMRZ9&P=7
Depending on the amount of imbalance , the lowest cell can be pulled too low and/or the highest cell can be charged too high without knowing. If it get too far out of hand (over or under) then that cell(s) will be damaged either imediately or over time.
