What is the Best LiPo Race Charger?
I think that the Carbon stops the charge cycle when the pack hits 8.4 V, whereas the Ice / Checkpoint TC-1030 start decreasing the charge current when the voltage hits 8.4 volts, until the charge current hits 0.10A. This is why it seems that the Ice/TC-1030 take forever to finish charging, since they actually fully charge the pack.
I like the Pulsar 3 because you can calibrate it. When it charges to 8.40v, it's actually 8.40v (or 8.43v). My ICE would actually only charge to 8.35v. It's a mental thing.....
I just ordered the Hyperion ---606i something. I need a second lipo charger and it balance charges. The easy balance feature will add another level of maintenance without hassle. I think balancing is a little over hyped, but for $120 your not going to get anything more convenient.
i like my MRC 989 superbrain>>>I wanna try the Checkpoint lipo charger sometime
Hyperion EOS0610i DUO.
#20
these charger will ok ,
because 1 format only !
http://rcmarket.com.hk/product_info....oducts_id=4491
http://rcmarket.com.hk/product_info....oducts_id=4106
#22
Hands down best bang for the buck is the Check Point 1030. It will trickle charge all the way down to 0.05 or even less I think. Takes forever once it switches to constant Voltage (CV). Others cut-off when they hit 8.4v and never switch to CV, or they will not trickle as low as the Check Point does when they switch to CV. There is a lot left to be charged if you don't use one of these. I also charge at 2c (7.2A) but that's done pretty quick, and then it switches to CV when it hits 8.4v, and the current drops way down, which is what most will do. Its the cut-off point that really matters. It needs to keep pushing in the charge to get a full run. I ran mine on the discharger when I was charging with a different charger that cut-off at .4/.35, and it gave inconsistant discharges, and the ave voltage was all over the place with 25a discharge. Its much better with the CP1030, and repeats.
The next best is sold only in the UK, and is a MultiPlex 6015, and does a lot more Lipo functions than most. They are not cheap though. A lot of chrgaers seem to be limited to 5A charge rates, and its another reason the CP1030 has the advantage.
#23
#24
#25
It's hard to beat Hyperion with the upgradable software. The AC/DC version is nice if you don't plan on charging above 1C. The DUO is sweet if you need to charge two packs at once, and will go up to 10A per side.
http://www.allerc.com/product_info.p...oducts_id=3367
http://www.allerc.com/product_info.p...oducts_id=3589
Hyperion also has some PC software you can use to watch your packs more carefully while they're charging. It's neat stuff, with pretty graphs and the like.
Does anyone have this charger on here that has charged two packs higher than a combined total of 10 amps? I had called Maxamps about this charger and the guy stated it would do 10amps total, not 10+10? Curious to here what a personal owner says.
#29
Balancing is over hyped? Just wait til you get a one bad cell and your non balancing charger and pumps in over 4.2v on the good cell. Puff city baby, or even worse.
Almost burned down my buddy's Explorer at the flying field because he forgot his balance taps at home.
#30
Hey guys I was able to really work with a Core UDC charger this past weekend and it is nice. I found that if you do balance charge, you can see the voltage of each cell in a different screen. You can actually see what the charger is doing to the 2 cells.
Also, I had a question about it this weekend and was able to talk with Adam Bailey from Schumacher this morning asking questions about the charger. I know that the customer service is great from Schumacher.
For the price the core charger is a great deal also. Not to mention the blue display is nice as well.
