evader st (electric) ball dif  questions >
Old 09-01-2003, 03:10 PM
Default evader st (electric) ball dif questions
i belive i have it as hard as it can be set and yet it is still to soft
is there a company that makes a spool or locker that will drop in place of the original dif?
PC
proudcanadian is offline
Old 09-03-2003, 12:19 PM
If you are really sure you want a locked diff then you could glue it together or something but only as a last resort of course.
igkyoa is offline
Old 09-23-2003, 12:31 PM
i have a nitro evader st, and i believe they have the same difffentials as the electric does, if you have it as tight as it can be and it still turns, maybe the diff. balls wore down, if you replace them. If you run them really tight and they continue to slip they will wear down really fast. you can get a carbide-steel type ones i think also. Just check out duratrax.com
prestonrice is offline
