Roar Region 8 off road champs
#196
I've been using the Hi-flo b4 body since January, and like it well. I can't tell a huge difference in the handling, but it gives you more room on the electronics, which keeps them cooler. Haven't tried the T4 yet, but will soon.
later
later
#197
R/C Tech Elite Member
If I remember correctly... Buggys were using ground down pink tapers all around for when the track was wet... and then when it started to dry out, people were switching to new pink tapers up front with Pink BK Bars in the rear.. Right?
What about truck? Just a set of pink taper slicks for wet, and a regular set of pink tapers for when its dry? Just need to get the right tires this time.
#198
Bschorr-That is correct on tires. The only thing I do differently, is run ground down 06 pinks on the buggy. I don't personally care for the 07's up front on buggy. You also might consider having a set of M3 Blades for the front of the truck. They seem to be a little smoother when the track dries out.
Later
Later
#200
Yeah, when the track dries out.... instead of going to pink tapers all around, try BK bars with pink 3-rib pre-scrubs. I think Mack is suggesting you can grind the 3 ribs down some. Don't make them into slicks, just take off some more of the rib.
I take it Froboy isn't coming with you Ben? Tell him to stop being a sissy
#202
yeah, I actually take the ribs down just a little further. They seem to push a little when they are new, so I just square them up a little. Use a belt sander, just don't get them to hot, or they will gum up.
#203
#204
im tired of waiting........need to run off-road
let go to chilli break down the doors water the track and run the old layout
#208
I've experimented with it in the past, and found no need for it.
#209
Ya, I see that there is...
Open Mod Buggy
and...
Mod Buggy.
I hope everyone signs up for Open Mod buggy so it doesnt leave anyone out.
Shouldn't be whining about a ceratin brushless motor when it comes to mod... Your Buggy could go 100mph or as slot as a rock crawler! its MOD!
Open Mod Buggy
and...
Mod Buggy.
#210
Let's keep this thing on page 1. We are only 3 weeks from shearing off A-arms from the wicked traction at Chilli. Let's start a roll call from Each area. I think Iowa will have the following; Myself, Jrod, Rico, Brandon, Chris, Cam, Kurt Johnson, Kenny Paxton, Jake Ward, Dustin Peckam, Dave Darrow, Mike Sanders, Lee Patterson, John Bolton?, Anybody I may have missed? Let's take over the town!!!
