RB C6BBT, what other plugs can I use?
Just wondering if anyone can list what other brands of plugs you are using with success in your Turbo C6's.
RB Plugs are costly and scarce in my area, any input is appreciated.
I also plan to run Byrons Gen 2 30% Nitro, should I be adding a headshim. I am at sea level.
Thanks Sean.
Thanks Sean.
Any nova made plug, Novarossi, RB, JP, Top, Rex, etc. Do NOT use OS plugs. Haven't tried Odonnell.
Also, the C6 should run fine on 30% without adding a shim but since you are worried about plug prices go ahead and add it. Plugs will last longer.
Thanks for the quick reply guys.
Cheers
Cheers
the odonnel turbo plugs are pretty good and seem to last a long time
Just woundering, why dont o.s. plugs work for the c6?
Just wondering, why dont o.s. plugs work for the c6?
OS plugs will fit and the motor will run fine but due to a different taper they may leak. If you crank down hard to try and kill the leak you will distort the taper in the head and then all other plugs may leak.
OD97T is the only plug you need to have
C6 runs great on it
C6 runs great on it
If you run 30%, Rb and Rody reccommend an extra head shim.
www.rb-usa.com check out the forums, many times this has been answered.
I have an OS plug in my C6L2G and am having no problems, yet anyway....
good luck with yours!
How many shims come with the WS7III standard plug? I got mine used I just never fucked with it and been running 30%.
