BEST PIPE FOR RB
Registered User
I have run a 2045 on my C6... but if you really want to see what that motor has install a 086(even 053 is wicked) tuned pipe, makes the motor come alive, way more torque,HP and RPM then the 2045...you will think you have a different motor !!! the 2045 is a very restrictive pipe that greatly reduces the C6's power output...
the torque is not that obvious.
i have tested my c6 with a JP3 pipe. i would say jp3 is better than the 2045.
what pipe is the 086 ir 053? is it the rb pipe as well or novarossi pipe ?
R/C Tech Elite Member
Thats why RB packages up the C6's in combos with the 2045
Holy crap! If your C6 feels dead on the 2045? OMG... I run that combo and its totally off the freakin hook! I wouldn't want any more power and I have mine tuned a little rich... Which btw RB engines like to be a hair rich... I think you just didnt have it tuned right with the 2045... At least thats my opinion...
by the way how inwards is your high speed and low speed needle screw?
is it as flat or much inwards ?
i have a guy telling me that he screw it flat and he run the engine at 160 c.
i feel that its way too hot.
#20
#22
The 086 or 9886 was the last great 2 chamber pipe from Novarossi. It dominated on-road racing before the three chamber rule came out. It also made a fantastic off road pipe though many people preferred the power band and better mileage of the older 053. They were sold under many different brand names including Novarossi, Rex, Top, RB, JP and probably some others. I think the 086 is still the most powerful pipe you can find for any Nova based .21 if your rules still allow it.
#23
i stil hav a novA 9886 but its not and inline pipe. its those using gasket type. perhaps i should get the manifold and try it.
#24
WOW 5 or 6 hour inwards for both high and low speed needles? that is pretty linwards and lean. well i got to try , i am not sure how much should i screw it in.
#25
Be careful going by others needle settings. Fuel and pipes make a big difference on tune. For instance, when I switched from white lightening to Byrons Gen 2 all my motors had to be leaned out about one full turn on top. I also once had my nice RB pipe get smashed and had to put an old RDLogics pipe on it. Again had to lean the motor way down from where it was before.
#26
While I do not know if Nova still makes the 9886 I have seen it listed here and there. I think RB still has them. Inline and old style.
#27
yeah i know changes in fuel and pipe usage does make a different in tuning the engine. i got a 9886 pipe but its not an inline type. i bought a manifold and will try it next week.
i just shim up a bit for my c6 as i do hav plug failure pretty often. i guess it the shimming that contribute to this issue.
cheers
#28
Excessive rpm can cause plug failures as well.
#29
I have a Murnan Modified RB C6 with the 9901 pipe and a 98mm RB header. It is a very smooth package with a ton of bottom end as well as a screaming top end. Motor consistently runs in the 220's on a 90+ degree day, and depending on the track size I can get 11-13 minutes (in a Mugen Truggy) on a fuel run.
#30
