Rc10ntc3
#3511
jscamry: Where did you get that aluminum strip? Is it hollow inside?
#3512
fast harry wuz up?
listen i have a little problem...c if u could help me ....
i spoke to u earlier at ron's and as soon as i got home i fire my T C 3 up, and a noticed that every time i punch it , it pulls hard to one side ......what is it that i did wrong or what could be the problem?
i have a SIRIO 12 outlaw........HELP plissssssssss
#3513
Originally posted by onroadmaniak
fast harry wuz up?
fast harry wuz up?
the tires aren't warmed up......the diffs are adjusted wrong,the car could be tweaked(are all the shock shafts teh same length?)...all the cvds together?(none slipping,all 4 wheels driving?)...........maybe one of the belts are loose..
#3514
Originally posted by OB42TC3
I was thinking about the comment about people going to MTX3s turning better lap times and all I could think about was how easy it is to overshoot with this car because it doesn't bleed off speed like the belts do, One of my driving flaws and it is really tough for me not to do is overdriving the car and not letting off soon enough; that corner entry speed is a big problem
#3515
FAST I HAVE A ONE WAY AND SOLID (R) AND THARE'S NOT BELTS ON A TC3 ARE THERE?
AND IS ME THE KID THAT SPOKE TO U AT CRUZIN...REMEMBER?
#3516
I know who you are......my mind isn't that shot......maybe one of the bearings is slipping in the one way....what tires do you have?
#3517
R33 HPI SLICK....CAN THE BEARING BE BAD IS BRAND KNEW.....
i finish the car a couple of days ago...
i know ur not shot but remember NTC3 don't have belts...ja ja ja ja (joke)......the tire wheres HOT!!!!!
and the problem is only when i go from mid to high that's it .
#3518
so you coast it along,maybe around half throttle,gas it,and it veers?...
#3519
yeap!!!!!! could it be the engine? to much torque?
1.45 hp should i get rid off the engine?
or should i keep playing with my IMPULSE?
it happens after i PUNCH it........mid to high.....!!!!!!!
#3520
t
#3521
you should make sure the car is set up as per the book..put the diffs back in,(always start stock),run the car on a level surface,make sure you have traction(either from the tires OR surface)..and bring it racing and I'll check it..BTW,my 2 tc3's(both with RB turbos,one a 5 port),don't do that....and that hasn't been a problem anyone else is having either..so stay calm,we'll figure it out....and put the diffs back in!!!(at least till we get it running straight)..
#3522
yes SIR!!!!!!!!
I'LL DO THAT ........hummm but i have to buy the balls for the diff i think i lost them when i put the front ONE WAY in or if not
i'll go to cruzin maybe friday....i look first...
thanx.....
i will get on that right now.........
thanx.....
#3524
my freind wants me to go to ediison on May 4th..instead of racing out doors buggy at barnstormers in NY..
I've never raced on foams,but I'm thinking about doing it......I'll run my tc3,hes going to run 1/8th..
#3525
This Sunday is practceand next is the first race day. I will be racing my tc3 and mrx3. I stand to do alot better with the tc3 since I have been running it for a year now and have it really hooking up. Let me know if you go. You can shoot me an e-mail or pm and maybe we can hook up.
