Like Tree2Likes
Rc10ntc3
Old 01-04-2003, 10:10 PM
  #2041
ilaybrk's Avatar
I like the clutch. but the K factory has more adjustable.(ps) k factork has o lower cg I am runing the K factory mounts 1mm lower
ilaybrk is offline
Old 01-04-2003, 10:24 PM
  #2042
finchy's Avatar
Default k-factory clutch
hey are you talking about the k factory centax clutch, if so I would be interested to hear what you think about it, as my shall arrive in mid January (things are slow to get to Australia). And is there any tricks to set it up
finchy is offline
Old 01-05-2003, 07:41 AM
  #2043
NTC3NUT's Avatar
theRED5, I thought I saw something from the K-Factory website about all the ports on the fuel tank being adjustable. Her's the blurb from their site:
The fuel tank has a lower CG than the stock one. It makes the handling much easier. Not only this good feature, it has many adjustable functions, including the adjustable tank lid lever, top inlet & inside inlet. All these three parts are adjustable. You can direct them to the angle you need. There is an inside chamber designed to prevent backpressure tube from being blocked.
Hope this helps. I have a tank on order, was $ 25 shipped from Hong Kong.
NTC3NUT is offline
Old 01-05-2003, 10:29 AM
  #2044
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Originally posted by NTC3NUT
I like mine, I have 2-sliver & 1-blue, all on NovaRossi's. I have the shirt too!
NTC3NUT or anyone with Crazy nut heads: Which head is compatible with the Novamega SX12RE 5P-T and Mugen MR12 engines? Can't find it on his site. Will the MT12 head work?
BOLISARIO is offline
Old 01-05-2003, 10:53 AM
  #2045
NTC3NUT's Avatar
The MT-12 head he has on his site will work with any NovaRossi (or Picco, I guess bolt patterns the same)based .12 engine. You will have to use your original button of course.
NTC3NUT is offline
Old 01-05-2003, 11:28 AM
  #2046
BOLISARIO's Avatar
Oh, ok....so it doesn't matter if it's a short or long rod engine. There wouldn't be any clearance issues.
Old 01-05-2003, 12:25 PM
  #2047
Boomer's Avatar
No since the "head" is really only a heat sink. You have to use the "button" (which is really the head) that you already have.
I just installed mine and it rocks!!!
Boomer is offline
Old 01-05-2003, 07:49 PM
  #2048
BOLISARIO's Avatar
Thanks...just ordered a blue MT12 head.....how much taller are the CNR head compared to the standard novarossi head? Will CG be affected? Can't wait to compare temps at Crystal Park. Gotta break-in the engine first.
Old 01-06-2003, 12:09 AM
  #2049
theRED5's Avatar
Default KFactory Tank
I ran the tank today, and it works fine, multiple tankfuls with no fuel evaporation.
The lid is adjustable, the fuel delivery nipple is not.
theRED5 is offline
Old 01-06-2003, 05:00 AM
  #2050
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
Bolisario- The head will be taller but it actually weighs less than the stock head does overall so cg can't be affected too much if at all. And any cg difference will be well worth it in the performance gain of that heatsink. Enjoy.
Jon
Jon Carlson is offline
Old 01-06-2003, 08:19 AM
  #2051
Default ntc3 rubber setup
Hi , I live in brazil and i am a r/c driver and dealer from
associated products in my country, i am running my ntc3
about 1 year with rubber tires ( because here in brazil we only
use rubber tires on races (rules of local champ)
i always see it is difficult find setups for rubber around the
world for ntc3 because it is usefull foam tires, by the way
i developed a great set up for my ntc3 asfalt medium/high grip)
front:
spring: ass white
oil: 60w piston 3
shock position: tower - same used by pavidis on worlds
arms- outside
caster: std
camber: 0,5 neg
toe: 0,5 out
ride h: 5,0mm
droop: 4
blade roll bar flat position
camber link: std
rear:
spring: ass yellow
oil: 40w piston 3
shock position: tower- middle hole or outside hole
arms- outside
camber: 1 neg
toe: 2,5 in
ride h: 5,0mm
droop: 3
3960 rear sway bar
camber link: std
tires: sorex 40r with hpi blue insert
rims: pro-line 24mm
diff adjustment: std set up front/rear
gear: 52/48 21/25
engine: sirio 3 port
byron 20%
glow: nova 6
pipe : std
body: stratus
if someone have another tips please put on forum:
i would like to know if someone nows where i find the
gears from the diff (3903/2329) with another material ?
fabian is offline
Old 01-06-2003, 08:38 AM
  #2052
Corse-R's Avatar
Default Re: ntc3 rubber setup
Seems that the factory are testing new materials for the diff and the main gear, according to what I've read the other day on the NTC3 talk at AE website, but don't hold your breath can pass several months until AE decides to lauch the improved parts and much possibly are launched as a rolling improvement (sheeesh! I hate when factory releases new parts with the older part no.).
I have collected some tips, tricks and other info from all the people on the forums and put on the original NTC3 manuals, PM me with your e-mail address and I'll send you a copy.
Corse-R is offline
Old 01-07-2003, 05:37 PM
  #2053
Default What do you think of this?
E-mail me if interested. [email protected].
nitrodude is offline
Old 01-08-2003, 12:21 PM
  #2054
Unhappy Help please!
Hi i just got my car started yesterday and for some reason the car was making a constant 'tinging' noise coming from around the clutch area ive took the clutch apart and cannot see any problem the noise can only be heard when the engine is idling this is with the car on my starter box im using an STS engine anyone got any ideas what or where the noise is coming from ... anyone else also hearing this noise? its just i dont want to 'knack' my car havent even driven it yet!
deanspoors is offline
Old 01-08-2003, 05:14 PM
  #2055
the tingling sound comes from the ultra lightweight heatsink.
try to shimup .1mm and see if it helps.
fuse01 is offline
