Hmmmm does anybody know the effect of....
Awesome thread.
someone missed out, this was a perfect chance to use one of those funny "STFU noob!" pictures
Suspended
I don't think anyone has given you an answer yet, too bothered with arguing amongst themselves, so I will.
O-rings on the shaft outside would be a bump-stop, to limit compression travel. It is not something I have ever seen seriously used in RC although they are common in full-size motorsport.
Ideally, you should only use a bumpstop to stop the chassis from bottoming out over the biggest bumps and kerbs. If the car rides on the bumpstop in normal running, you will lose a huge amount of grip because the suspension will effectively run out of travel.
Another reason to run bumpstops is to stop the driveshafts from popping out or similar issues, I know that with my old, old HPI Pro3 I had to run quite a few o-rings on the shaft otherwise the driveshafts would pop out in crashes.
Hope that helps.
Hope that helps.
Sometimes I wonder why people spend so much time bashing and then others piling on. It's like a bunch of kids in the schoolyard.
#21
the Dr- if shock collars are not for changing ride height, what are they for? explain your logic.
dont be shy lol
dont be shy lol
#22
Location: Colorado, USA, The land of the free and the home of the brave!
They are for setting "preload" when you have your ride height set and no downtravel, duh!
yeah, this thread has gone downhill, sorry xraycer, clever name, welcome aboard.
#23
I think all ol' Doc was doing was trying to do was prompt the kid to read the manuals and tech sheets that the xrays come with or is available on their website. Otherwise the kid comes here and he gets bombarded with a lot of contradictory information he's not sure where it comes from.
#24
#28
What's an O ring?
#29
You should only hit the bump stops momentarily, use them for protection when riding the kerbs or the biggest bumps, not in normal cornering.
If you want to run soft springs/lots of chassis roll but have problems with bottoming throughout the high speed corners, raise the ride height.
