Rook? Diff Oils - How do they affect Setup/Performance
Hey guys been into racing now since last fall and I wanted to get your input on diff oils and how they affect setup. Ligher weight oil does what? And where? Center Diff, Front Rear? I've been running the stock oils in my 8B & T and wanted to know how changes might affect it. Thanks guys.
diff oils affect alot.. different weight can increase steering, traction, etc
Check out the link below. There is some good infor there.
http://xtremerc.com/pages/howto.php?howto=24&page=3
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
in front, the heavier the diff oil, the more traction you will have, but it takes away steering.
In the rear, the heavier the diff oil, the more traction you will have, but at the expense of steering, "rotation" in a turn, and stability over bumps and ruts.
In the center, the heavier the diff oil, the more aggressive the car will feel.
Beat me to it^.
Front diff fluid: Thicker fluid = better stability off power. Better steering on power.
Thinner fluid may mean better off power steering, but steering on power will often become twitchy.
Center: thicker fluid means better acceleration. Your on-power steering will be better, off-power steering will be reduced. If you go thinner in the center, you'll have more power up front. Your fronts will "unload" because it's super easy for them to spin and balloon up like crazy. If you've ever tried to control a car with excessive ballooning, you know it's not fun. The car is all over the place.
Rear: Thick fluid gives more forward bite, but you'll oversteer in the middle of a turn because both sides are trying to spin at the same speed and struggling. Thin fluid lets you corner better at the expense of the forward bite.
Typical starting points are 5,000F-7,000C-2,000R for buggy and I think 7,000F-20,000C-5,000R for truggy?
You want to avoid things like unloading, where one diff gets too much of the power and spins too much more than the others and the tires balloon up, you won't be able to control your car.
You want your car to pull, not push.
well i race a muggy and i run
front 7000
center 10000
rear 5000
i found that that i a good combo for me i just kept screwing around with them until i found a combo that worked for me
front 7000
center 10000
rear 5000
