vspec carb problem
vspec carb problem
hi there im trying to tune my vspec it is great on the bottom and top but its realy rich in the middel and im a bit worried about messing with the mid needle could anyone give me some tips or info cheers first time with 3 needle
carb so dont want to go at it like a bull in a china shop
Don't mess with the mid range needle
I have not specifically tuned a Vspec yet, but have tuned 3 needle carbs hundres of times. First make sure the 3rd needle is at or very close to the stock setting. Generally I will get the engine tuned using only the main a low speed needle. Only then will I adjust the mid needle, and make coresponding adjustments to the low and main needles.
It sounds like you may actually be lean on the bottom, and compensating by a rich main needle, and the engine is just not clearing out.
What plug are you using?
FWIW - Hundreds of happy V-Spec owners have set the mid needle to the following position (myself included) and left it alone after that:
Set the mid needle flush with the carb housing. Then turn the needle clockwise until the slot points to 2:00. This is for a stock V-Spec. Speeds have a slightly different setting they seem to like (4:00)
I've played with that needle from noon to 4:00, and it's a very noticeable adjustment.
NEEDLE SETTINGS:
High Speed - (see pg 17 of manual) 3 turns OUT from fully closed
Metering Needle - (see pg 22 of manual) Head of screw is flush with
ball link body
Mixture Control Valve - (see pg 22 of manual) Head of screw is 1 full
turn IN from flush with carb body
ball link body
that one isnt measured in 'turns' like the others...
set it up so that your idle gap is about 1mm and adjust from there
