CA gluing carbon chassis components
Medium to Medium-Thin CA.....put a big puddle of it on a plastic cap or something that you can just throw away....use Q-tips.... Roll one of the ends of the Q-tip in the CA puddle and then use the Q-tip to apply the CA evenly
If you screw it up, just use some acetone to take it back off. Just let it soak a little on the glue and wipe it off.
I've found that the q-tip method mentioned above works best for me.
Listen to Fred... He is right on when it comes to this. I also use the Q-tip method but i usually use a thicker glue if i have time. But if i am in a rush then i use thinner glue to dry faster then redo it later when i do have time...
Mike
Mike
you can use debonder to get unwanted ca......great planes makes it..
http://www3.towerhobbies.com/cgi-bin...?&I=LXK299&P=7
A quart of acetone will last pretty much forever and is about the same price (at least I think it was 2 years ago when I baught the last can).
Location: Colorado, USA, The land of the free and the home of the brave!
I sand the chassis with progressivly smoother sandpaper, then i wash all the dust and debris off, then i spray some CA accelerant over the edges and when doing so i let it "soak in" for about 30 seconds. After doing so, i wipe the excess off (leaving accelerant on will leave a white, crusty finish when the CA dries). I then hold the carbon fiber plate (shock tower, chassis, etc) vertical so i can apply a small drop of thin CA and then i let it "drip" around the edge of the chassis as i countenually rotate it. It only takes about 2 or three drops, and if applied right, the CA accelerator will prevent the drip from flowing on to the rest of the chassis. You can also easily do this on the negitive (or cut out) portions of the chassis such as battery slots. This method might not be as easy as the q-tip though, but it worked for me.
Get some of these: http://www.sparklesbeauty.co.uk/images/cotbuds.jpg
Then apply the CA to the end, let the cotton dry out, then apply more to the tip and slowly work your way around the edges, rolling the tip if need be.
And as mentioned, yes the thicker CA can be easier to work with
hth
hth
