The Spool Shimmy
The Spool Shimmy
No, its not the latest craze sweeping the nation's dancehalls - it is a little handling trait I have noticed - and I wondered whether other people had too.
When you run a front spool, quite often you can get a wiggle from the rear end when you put the power down hard out of a corner.
On flowing grippy tracks this phenomenon isn't a problem, but I raced over the weekend at a tight carpet track that started off "green", and with rubber tyres the car could be quite a handful, pitching off-line so much at times that I hit the track markers at certain places.
Switched to the diff and the car was a lot more settled, a lot more consistent and a lot faster as a result.
Technically I imagine it is something to do with inside front wheel being over-driven compared to the rear, or the forces from the spool trying to straighten out the steering too suddenly.
Is this something that other people have experienced too? If so, how did you tune it out, or do you just learn to deal with it?
I think you fixed your problem by ditching it. You can't be dead set on having 1 setup work everywhere. You found a track layout that made you not like the spool, so you switched to a diff and the car was faster. I personally don't like a spool, and will honestly never run one because of how it felt. Time-wise I'm faster with the diff, so who cares what the next guy does.
thats fine but a spool is still normaly faster on pretty much every race track just look at the world class drivers andy moore marc rehinard mike blackstock etc and they all run spools most of the time yes you got the car working well with the diff but a setup alteration i think would make a spool that much faster then you would be twice as fast as you was in the first place
Super Moderator
Spool is never a good idea on carpet. As you already found out it makes the car very inconsistant. You either run a diff or a oneway. Spool is mainly for asphalt.
I have seen on a very small,tight/technical carpet track (10x15m) a diff with foams and a stock motor is just as capable as a 13.5 with rubber (with a spool I think). The smaller and more technical track the more low speed steering you need.
With the right foams I could put down as much power as I wanted to and the back end stuck, if you are just as fast as the guy next to you it doesnt matter how the car is set up I guess.
When space is limited there is only so much power you can put down, but maybe now i'm on the verge of being off topic,lol.
I too have noticed the shimmy you mention.
I just figured this was from wheels fighting for which direction to pull the car and I learnt to deal with it.
On carpet I found a diff much better.
On asphalt, I am running a spool and I am liking it more than the diff atm.
That being said, traction levels and track layout call for different setups. On a less technical carpet track I might try a spool. On a more technical asphalt track I might opt for a diff.
But in the end, I'll use whatever gives me the best results
-Mark
-Mark
When i ran foam tyres on asphalt with the spool i found the "shimmy" to be irratating thinking its was tweek or something else.
I went slightly smaller on front tyres and it helped tame it down a lot.
Maybe it just needs some overdrive to help it pull out of the corners a bit better.
Outdoors on asphalt with rubber there is no signs of the "shimmy"
ive ran a spool on many indoor carpet tracks and it has always been faster and more consistance
I have found on smaller technical tracks running 10.5 with rubber tires the spool actually works better especially layouts that have tight turns with short bursts of speed. This made it easier to get off the corners quicker and more importantly drive it deeper into the corners and avoid being rear ended running in a tight pack. The only thing that was required was to change the setup slightly to allow the car to rotate better at the lower speeds.
your carpet must be diffrent from ours in the uk we race on the biggest indoor carpet events in the uk over the winter (carpet wars) im pretty sure tht the top ten of every class ran a spool. mod included andy moore ( world champion) chris grainger (natinal champion) marc fisher (corally's number 1) ollie jefries etc in 19t my self stu rand (2x carpet wars champion and 2007 corally stcc champion) kevin brunsed and lots more now we all cant be wrong.
thats fair enough but i certanly wouldn't write them off
