19T Motor Forum
Old 01-02-2007, 12:18 AM
  #466
R/C Tech Elite Member
BSchorr's Avatar
Trader Rating: 101 (100%+)
So the KD is the hot motor right now? What about the CP 19? The reason I ask is because I heard teh CP with Infinity brushes can go a long time inbetween comm cuts and even longer, like 40+ runs inbetween brush replacement. I would be using it for 19t sedan.
I could see the 40+ runs if it were in offroad cars.
BSchorr is offline
Old 01-02-2007, 11:10 AM
  #467
dgullickson's Avatar
Trader Rating: 45 (96%+)
Originally Posted by fat_boyz
Yes, brush little stuck to move in and out from the hood.. how to solve this problem..? thanks
You can get a hood alignment tool and realign your hoods.
dgullickson is offline
Old 01-02-2007, 11:31 AM
  #468
Hockey 85's Avatar
First remove the springs that hold the brushs in and pull them out of the hood. Spray your endbell out with motor spray, then see if the brush moves in and out of the hood smoothly, then re oil your bearings and test performance on your motor checker and it should be better
Hockey 85 is offline
Old 01-02-2007, 12:27 PM
  #469
Suspended
RaceAce701's Avatar
Trader Rating: 87 (99%+)
hi everyon i am currenty running stock touring with a co27 with a 28 rollout
i a going to b running 19t soon i have a KD and a checkpoint $$ how will the rollout differ or about how many teeth shud i go up or down
RaceAce701 is offline
Old 01-02-2007, 12:39 PM
  #470
stiltskin's Avatar
Trader Rating: 103 (100%+)
Your CO27 and KD19 should rollout the same at 28. Not sure how to gear the checkpoint. I haven't been able to run one yet.
stiltskin is offline
  #471
John Tag's Avatar
Trader Rating: 42 (100%+)
KD.. Go up 1 tooth and $$ go up about 4 to start...
John Tag is offline
Old 01-02-2007, 12:46 PM
  #472
BSchorr's Avatar
John is pretty much right, CO27's at my track are geard about 28mm rollout. KD's are like 27-27.50mm rollout, and CP19's are about... 29-29.5mm rollout.
I tend to get a CP19 also and tinker with it
"I think" KD's are moer of a RPM motor and CP19's are a torque, i dont recall remember the numbers or anything, i just judge that by the rollouts.
BSchorr is offline
Old 01-02-2007, 01:27 PM
  #473
Suspended
RaceAce701's Avatar
thanks everyone that's exactly wat i was looking for
Old 01-04-2007, 09:20 PM
  #474
hey everyone i was wondering wat i should gear my komodo at on my track and the track is 80 by 35 and the car is a t2 on foams and has a 116 spur and also wat is a good brush and spring combo.
thanks jordan
mush104 is offline
Old 01-04-2007, 10:26 PM
  #475
tom235's Avatar
t
tom235 is offline
Old 01-04-2007, 10:50 PM
  #476
Tek Nickal's Avatar
Thats true, and the motor has great power if you gear it right, for on-road you probably won't get 40 runs but it'll be a lot if you don't overgear and overheat the motor.
Tek Nickal is offline
Old 01-05-2007, 08:34 AM
  #477
Johnny Wishbone's Avatar
Its true, I have over 40 runs on the same springs and brushes and only one skim on the com somewhere around on run 23. Its all in TC, big tracks, little tracks all tracks, even had it up to 180 degrees a couple of times, its just keeps on running hard.
Johnny Wishbone is offline
Old 01-14-2007, 01:15 AM
  #478
rs550's Avatar
Trader Rating: 20 (100%+)
Default gearing pls help...
ive been using a komodo express tuned on my t4 and im runnin on off road technical track in the phillipines i geared it 18t at 48p/87spur using pro line tires on the rear, how can i make it more faster with lots of torque should i gear it 17t? or should i change the brush? can anyone tells me which brush is the best for 19t? tnx...
rs550 is offline
Old 01-16-2007, 12:42 PM
  #479
tom235's Avatar
what brush are you runnig now
tom235 is offline
Old 02-01-2007, 07:47 PM
  #480
whats the best springs and brush will be good to a small technical track?
i think i have some f brushes.. just wanna know what spring combo is good?
chameleon 2 is the motor.
asphalt rubber tire. mid traction lots of turns.
thanx
jinkasama is offline
