19T Motor Forum
#166
Trader Rating: 13 (100%+)
cause I like to quote crap...
Onroad 19T
5-55: Rebuildable 19T “Super Stock” motor armatures must be machine-wound using a cross wrap technique. The legal 19T “Super Stock” wind is a minimum of 1170mm of round 19 AWG (American Wire Gauge) wire, having a maximum wire diameter (including insulation) of .914mm, resulting in no less than 19 continuous turns of wire on each pole. There is no tolerance on the minimum length of wire, nor is there a plus tolerance allowed on the wire diameter.
Stock
5-37: All rebuildable stock motor armatures must be wound using a "Mabuchi" cross wrap technique, and a process that locks the commutator and the armature stacks so that the timing cannot be changed without disassembling the motor. The legal stock wind is a minimum of 64 inches of round 22 AWG (American Wire Gauge) wire, having a maximum wire diameter (including insulation) of .67mm, resulting in no less than 27 continuous turns of wire on each pole. A production tolerance of one turn on one pole only is allowed. There is no tolerance, however, on the minimum length of wire, nor is there a plus tolerance allowed on the wire diameter.
Stock
#169
I have another question about a chameleon 2 pro i bought used not to long ago...i took it apart to clean everything and the arm magnets have 4 good size drill holes in each part...12 in all. i know someone had to do this themselves, but what does it do for the performance?
#170
Rcnitrodude,
Sounds like someone got crazy with the drill and dremel tools. It is highly illegal to drill out the armature to lighten it up. Although it will give you a faster spool up time you will probably throw the balance of the arm off so bad you will not reap the benefits, especially 12 holes. Like i said before, it is an illegal motor and will not pass any Roar tech inspection at major races.
#172
Regional Moderator
Originally posted by Proteus
Don't you race down at Fernando's track? I remember you. So I hear your gonna be running the R40? Good. Find me a setup so I can come back down again. See ya guys soon. Your going to snowbirds, right?
and yep, .I'm going to Snowbirds. I think we have our 415s pretty good. Arun and GA boys are up there at Novak right now....and we will see if their Tamiyas can get at least in B main - 19T.....
Buy regular chameleon pro arm and put in C2 can
this combination is the best so far.
...of course....hemi wound is better.....no cross wrap for me!!!!!
Oh, try F brushes from EA Motorsports too...awesome....
#173
Originally posted by kumpol
yes.....R40 baby.....can't wait to run it - I had pretty bad luck last season with 710.
But regular chameleon pro arm and put in C2 can
Yeah, I got some F brushes coming – wanna try them out as well.
Sutton called me the other day. He is working on his new car. Proteus is a hack! Don’t waste your time talking to him
Hope you have no one that you know down south near Phuket. Just spoke to my Mom 2 days ago, horrible!
Any how, as far as a 19T motor I’m still running a good old Promatch – its still pulling 114 watts on the DYNO…
Maybe sometime in the summer I’ll ask Sutton if he wanna go down to GA with me.
Later
#174
#176
#177
Regional Moderator
Originally posted by kidDynomite
Kumpol, I'm running a Chameleon Pro and was curious to what a C2 can was? What about the spring combo. Thanks!
Springs? depend on what brushes you put on.
I have 767 with verticle slot and purple spring for each side.
#179
Tech Legend
Trader Rating: 51 (100%+)
Originally posted by PIIHB!
What is the best 19T spec motor? This is for TCS.....
#180
Regular Chemeleon Pro arm and Chameleon 2 can.
