TAMIYA F103 RM
#1816
As far as the shock, I always felt that raising the shock makes the car turn more on power and vice versa. That was what I found with 1/12 cars. With the long wheelbase of the F1, it seems to help, but I think it is mostly personal preference.
#1818
The stock/inline knuckles seem to get a twitchy feel if conditions are right where the trailing knuckles seem to have a smoother feel.
This is a general statement from what I have noticed a my local indoor carpet track.....
Hope this helps!
#1819
The offset/trailing knuckles provide less steering entering(off power) a corner and more steering(on power) exiting a corner.
Hope this helps!
Hope this helps!
#1820
Hate to be that guy that asks a question that has probably been answered... but... I'm at work and am heading to the hobby shop when i'm done.
Last time i was there i noticed he had some Tamiya F1 "B" tires, front and rear in stock. Worth picking up for my car or should i look elsewhere. He actually had two sets of each. I'll be running silver can on concrete.
Thanks in advance!!!
#1822
Hey all,
This may have been covered already, but what is involved in fitting an Orion 2400 lipo in the F103 chassis? I notice the pack is much longer, so do you use tape, modify the original mount, or is there a new mount for this style pack?
Thanks for the help.
My car is an F103RS, if it helps.
#1823
Hey all,
#1824
Painting Wings & Rims
I am painting a new livery and want to paint my wings & rims a different colour. Right now they are brand new, all black, might be painting blue or white, and rims silver. I guess same goes with the helmet...
Has anyone done this before? Will the Spray Can PC paint (for lexan bodies) be okay or should I use something like Testors Model paint, but what type of paint? Enamel, Acrylic, or Lacquers?
#1826
Cross Racing has front and rear wings moulded in red, yellow, blue, white and black. Here is the info (scroll down to about mid page):
http://www.rc-cross.com/page/FireForce2008_parts.html
#1827
HBR Foams?
Are the HBR type foams new (84097 and 84096)? what's the difference with "regular" foams (84094 and 84095)?
Thanks.
Thanks.
#1829
I have seen a lot of different servos, but I ended up using a Futaba 9650. Mostly because I had a spare. It takes a little work to get the location and height correct though. I mounted mine flat to the chassis. If I did it again, I would raise the servo a touch to reduce the bump steer.
#1830
What parts do i need to convert over after i get the 3racing 64/48p spur adapter?
