Engine Wars Thread
#421
Originally posted by Top Gun 777
This method looks absolutly correct.
#422
When they measure the exhaust port height do they measure it from the top of the port from the inside/chrome side of the port or the part you can see looking in from the outside of the case?
#423
.12 Engine Bearings
Does anyone know where I can find ceramic engine bearings for the newer V12 and NS12 engines? The 7 x 17 x 5 front engine ceramic bearing can be found at Boca Bearings (so as with the older RS12 and X12 based ceramic engine bearings) but what about the 11.5 x 21 x 5 internal main bearing? Any other sources? I know it's not legal for some races.
I know that ceramic bearings allow for higher revs but for the price, are they really worth it and do they really work? How much more rev can you get out of a stock engine with these ceramic bearings?
#424
#425
Qualifying Results
Qualifying at the 2003 AARCMCC Australian Nationals titles has now finshed after five rounds.See the report of Alastair Walker @ TSN.I want to know that who is Uncle Top Gun's Team Driver?
#426
Re: Qualifying Results
Sorry, I personally not aware about team,but will try to find out with team manager.
Tommy Lee was running Sirio which I did for him.
#427
Have serpent and trinity teamed up,cause i think the snakes are using trinity's dynos !!!
http://www.mytsn.com/products/specs.asp?prid=3189
#428
#429
Dino.TW i think you should BEG Trinity to let you use their dyno !
#430
#431
Re: Re: Qualifying Results
Is thereTop Gun team?
#432
Dino.TW i think you should ......!
Never let your horses eat too much.Then it will be looked like the left one.
#433
HP?
I have a question!Why it is always horse power?Why not "Dog Power"?As I knew that Eskimo use Dogs to drag!
#434
Re: .12 Engine Bearings
1. Order from Boca bearings a minimum order of 1000 units.
2. Disassemble one brand new bearing from Nova and change yourself the balls for some ceramic ones from a reputable vendor.
Sorry, planning to do on some, but actually don't know the measures of the balls (need to disassemble a bearing to know).
Did some times (changing the balls of the bearing) and found some more revs and found another fine advantage and more resistance to vaporlock the engines. If you go by the second option, you can get sometimes a 'gritty' feeling of the bearing, but is perfectly normal on ambient temperatures, when the engine is on operating temperature, everything goes fine and sweet. Don't get scared by this.
Of course, the second option is a little cheaper but harder to do (need to know how to disassemble the bearing and take care of not damaging the plastic carrier when assembling another time. For RS12/X12 and other 11mm cranks the balls are of 1/8" and you need 8 of them.
#435
Sheesh . . . change the balls!
. . . and we thought I was cheap.
Actually, can you even get them apart?
And what do you do about the wear that still exists on the inner race, the outer race and the cage?
