OFNA LD3 pro
#1411
Will do. I got the side exhaust because a) I didn't want to get another pipe and 2) it was only $100 new on Ebay. I sent it to RB Mods to have some work done to it. After running thru a few tanks, it stills wallop my OS even though it's not fully broken in and running very rich. The engine sounds like it will rev for days. I hope that 15/20 gear will work on my long track. If not, the 16/21 is going back on
#1412
$100 sounds good to me.. Im sure my Nova CX12 pullstart side exhaust has more balls then my Sirio did so that engine of yours should really go off.
#1413
Re: Joining the club
Originally posted by VRF201
Will my new LD3 Pro with Picco .12 is on it's way!
Thanks! to a great price from NitroHouse.com
$299.95
now that's a great deal!
The sad part, won't be here until friday.
Looks like I'll be asking for some advise pretty soon on
how to make the car hook up.
VRF201
$299.95
VRF201
#1414
Thanks!
Hopefully the car will perform as good as it looks.
Question?
Is there anything special I should do as I'm building the car.
VRF201
Question?
VRF201
#1415
Just take your time, don't rush. The ld3 pro was my first build and it has gone fairly smooth other than a few missing parts in my kit I had one threaded shock body that was junk, was missing a steering servo mount and just yesterday found that my kit is missing the manifold spring as well. I found that the kit went together pretty easy overall for a newbie like myself The only things I added during the build where the graphite top deck, graphite side plate, and I picked up the optional spring set. Have fun building your new LD3
#1416
Thanks IDrinkNitro!
Waiting is a bummer! Come on friday!
Question?
What optional parts do I need if any
or should I just run the car as is first?
From what I've seen on line and in a few magazines the
car runs pretty good out of the box.
VRF201
Question?
VRF201
#1417
Just run it...I would suggest the spring set, though, and adjust the gears depending on your track. The Picco should run pretty well, and I know someone that will mod it for you if you're interested.
Race day was a smashing failure today. Both diffs are fried. gears nice and rounded off, so they engaged when they wanted. I think I may have had 1, maybe 2 wheels under power. That brought things to a screeching halt. I think the screws in the diff backed out (or I didn't tighten them enough), and that NovaMega didn't help matters either. Do you know if they make 2MX8 flathead self tapping screws? I may grab some when I replace the gears.
#1418
Sorry! can't answer the question about the screws.
The track of choice will be Doug's each saturday once the car is done.
VRF201
VRF201
#1419
#1420
#1421
tamiya sell 2X8 countersunk self tappers, i bought mine in a pack of 10.. the stock kit scerws ripped my diff apart.. everytime id try to screw it back together with the stock screws they wouldnt grab..and then i got the tamiya screws.. im still using the same diff housing and havent had a problem to date with the rear diff
#1422
Can ya git us a part #?
THanks
THanks
#1423
ill have a look an see wat i can do
#1425
VRF201
VRF201
