OFNA LD3 pro
#1006
Have a quick question for you LD3 owners. I have 2 RTR's for my younger kids. What are you putting in the front and rear diffs? I have Mugen 100K, 50 and 30.
I was going to put 100k in the front anf 50 in the rear, but thought I would see what you are all using.
Thanks,
Smitty
Thanks,
Smitty
#1007
Well, I was talking about the centax that comes with the LD3
Originally posted by Darkseid
Not quite. At least not for all cars. The R40 comes with a nut that allows people to use a threaded shaft engine with their included centax clutch.
#1009
Pics as promised
Ok so here is my problem. I believe this pic shows the issue. I have this clutch nut screwed all the way in and as you can see it is not quite securing the flywheel
#1010
Sorry guys, not sure what I am doing wrong as far as posting the pics goes
#1011
Thanks,
Smitty
Thanks,
Smitty
#1012
here are pics of the clutch parts as requested.
The ofna manual says nothing of using a collet with a threaded shaft but from what I can see there is no way this will work without using the gold collet that came with the sirio motor. Your thoughts??
#1013
OK. one thing you should check. The threaded portion of your crankshaft...is this part of the crank or is it a threaded rod going into the crank.
You can normally tell by the way the threads go into the crank....if the threads stop before the flush portion it is part of the crank.....if the threads go all the way into the flush portion it is actually a threaded rod going into the crank.
Nova engines use threaded rod for their short cranks and you just have to undo the threaded rod and put an adaptor (from Mugen) to convert from short crank to SG crank.
However, either way, it looks like you will have to cut the threaded portion of the crank because your flywheel nut is for a short crank anyway. It may be easier to remove the threaded rod first before cutting...if that is what it is...... Good luck!!
Yes..you do have to use the brass collar.....
#1014
Thank you very much for your inputs. I will see if it is possible to convert the shaft, if not then I will break out the dremel, pipe cutter, or hacksaw
#1015
#1016
one more thing, use the collet that hong nor/ofna supplied. my flywheel was slipping after about a gallon of fuel used (this maybe due to the nut not tightened enough though.), just my 2 cents.
#1017
#1018
i decided
i decided to go with the pro and picco package
not to sound like an idiot but in all the gas cars i ran in the past i never used a fail safe
just what is it that the fail safe does???
#1019
Keeps your car from going crazy when someone else w/ the same frequency turns on their radio. I highly recommend it, and over here for racing it's mandatory
best investment I've made.
havy
havy
#1020
thank you
thank you for the info on the fail safe does it shut your car down or what
