Team Associated Factory Team RC10R5 >
Old 05-20-2012, 01:53 PM
  #796
My mod
shorty pack or normal 2s saddle pack
M.Abramowicz is offline
Old 05-25-2012, 06:02 PM
  #797
valk's Avatar
Trader Rating: 13 (100%+)
so my 13.5 is a pos and i cant really get anything out of it. wondering if i would have any success dropping my spare 17.5 in, and gearing/boosting it like a 12th scale or somewhere between.
would it be worth my while to fire up the soldering iron, or should i just sit out until the new motor arives?
was also tempted to just get a 10.5 and run blinky wgt. would it be competitive running against the prodominently D3 boosted 13.5s?
valk is offline
Old 06-07-2012, 12:22 PM
  #798
Josh-n-ya's Avatar
Trader Rating: 95 (100%+)
Two 10R5s for sale in the classified section. Will make you a good deal. Tons of WGT Spec tires. Cant do it any more, they gotta go. Sucks
Josh-n-ya is offline
Old 07-19-2012, 04:37 AM
  #799
CFR
CFR's Avatar
RC10R5, What does moving the Tweak Springs inboard by 8mm do for the handling?
like this
CFR is offline
Old 07-20-2012, 03:27 AM
  #800
like this
Bad url need login.
It is like in dtm, inside spring = softer feel, outside spring, harder feel.
Old 07-20-2012, 01:31 PM
  #801
like this
Moving them inboard results in a lower motion ratio... Thus for a spring of rate X, the effective spring rate seen @ the chassis will be higher with springs mounted outboard(say, on the links) than with them mounted 8mm inboard.
JamesL_71 is offline
Old 07-21-2012, 12:17 AM
  #802
CFR
CFR's Avatar
Originally Posted by M.Abramowicz
Bad url need login.
Thanks guys.
CFR is offline
Old 08-29-2012, 02:59 PM
  #803
Just a little modified 10R5
Old 09-18-2012, 01:02 PM
  #804
Johnn27's Avatar
Trader Rating: 89 (100%+)
Thumbs up 13.5 blinky gearing
What is a good starting point for 13.5 blinky wgt with a tekin??
Johnn27 is offline
Old 09-18-2012, 01:27 PM
  #805
Pro10noob's Avatar
Depends....1S or 2S?
Track?
Tire diameter?
Body?
regards Roy
Pro10noob is offline
Old 09-18-2012, 03:19 PM
  #806
Logi Maker's Avatar
Trader Rating: 56 (100%+)
Ran mine on 52mm tires, 88/45. LRP SXX SS-LRP x12 13.5
Track CRC carpet 104x48
Logi Maker is offline
Old 09-28-2012, 07:56 AM
  #807
Logi Maker's Avatar
Old 09-28-2012, 10:03 AM
  #808
AdrianM's Avatar
I wish AE would update the car. Current WGT's are working best with center lipo's. Just take the 12r5.2 rear end and damper assembly and bolt it to a new, simple rectangular chassis then both the existing front end to it. This new chassis would be cheaper to produce....fewer cut outs. Like a Speed Merchant WGT3 but blue and with the R5 front end.
AdrianM is offline
Old 09-28-2012, 10:33 AM
  #809
Pro10noob's Avatar
There is a lipo kit present for the 10R5 without drilling in the chassis.
Regards Roy
Old 09-28-2012, 10:41 AM
  #810
Logi Maker's Avatar
Rumor was a new kit was supposed to be released 1 month after the 1/12 scale ..... was thinking they would time it for Vegas... i hope the class picks up because more pan car classes the better.....
