Team Associated Factory Team RC10R5
#496
have one for sale cant afford more electronics brand new put it together never ran it
#497
hollywoodtc5 how much are you asking for it. PM me some info Thanks
#498
#500
Yes they Are
#502
How to fit saddle 2S lipo pack in 10R5
Hi!
I got some free time. I want to put my 2S lipo back and 17.5T engine to
my 10R5. In my country we try drive on 4cell or 1S lipo 13.5T but I got
bad luck and I destroy my 13.5T engine in DTM car so I want to back 2S
racing
I have some option for 2S lipo stick pack from UK but I don't like it,
for me it is not I want ...
Now I got new packet 2S lipo saddle from GM (4200/30C #98994) and
how to put it on car without made big mess.
For 1st time I put shock carbon tower to another direction, add some tube
for more length of shock.
There is pic:
Now you can see that blue part is moved about 3mm up.
Shock tube is too long (I will do it shorter).
At this pic you can see that lipo fit nice and we have some place for ESC
in the center
Now I must made short tube, probably cut new shock tower and test it
on track
m.
racing
There is pic:
in the center
on track
m.
#503
so idd you actually have to relocate the shock mount to fit the battery in behind it?
Hi!
racing
There is pic:
Attachment 566146
in the center
Attachment 566148
on track
m.
racing
There is pic:
Attachment 566146
in the center
Attachment 566148
on track
m.
#505
Hi!
Updated pics from my phone:
:-) now I need to cut off some carbon (part taken from 12L4 )
Center weight front/rear is on white tool, it is about 110mm from
rear axle Should be fine, because with 1S lipo SMC I can
have it in this line
So car is almost ready for 2S/1S only change engine for track rule
Regards!
m.
Regards!
m.
#506
Has anyone seen any benefits running a larger shock body like the other gt chassis? Would it help the issue with rear standoffs bending possibly, just because it is larger in its self?
#507
I can feel difference for oils, 250,300, 350 and for springs.
So for me it is better then oryginal ae.
Btw I saw oryginal broken in accident (that was in E12 12R5.1) and I switch to
bigger TC one. Now I have two side shocks and is easy to fast change (thin oil, thick oil).
I remember that with 1st shock from kyosho RRR, I put some o-rings between shock body and plastics spring holder
Wish you good luck!
m.
#508
Has anyone had problems with the front wheels getting stuck on the blue suspension mounts?
When I turn, the front inside wheel sticks out of the body and if this wheel catches the wall (I like to hug the corners), the wall actually shoves the tire back or turns the wheel enough to get it stuck on the inside of the rear blue aluminum suspension mount. The wheel has to physically be turned out to get it unstuck.
Any ideas?
Any ideas?
#509
It sounds like your tires are rather large to have this happen. You could try moving the wheel farther out on the axle using shims. I read about someone using a longer screw on the upper arm mounts along with some shims to act as wheel stops, but I am not sure about how well that works. Sounds a little fishy if you ask me.
#510
"Upper arm mounts"? Do you mean lower arm mounts? The upper arm mounts are on the other side of the bulkhead.
I am maybe considering a button-head screw on the wheel side with some shims to keep is from going past that point and getting locked in. It may help.
What do you mean by "fishy"?
